Home > Maintenance & Modifications > has anyone sprayed with an aerosol? |
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 |
Top tip,warm your part slightly with a hair drier before you paint,will help reduce build up on your edges. |
Tue Apr 01 2014 8:16pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
sounds like a great tip, mrfixit. many thanks for that !!! Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Tue Apr 01 2014 9:49pm |
so, i'm trying a new technique today with my lower tailgate trim:
Fri Apr 11 2014 4:58pm |
little update on the new spray technique...it's far far better! the thing that makes the difference is polishing with the 2500 wet and dry once the clear coat has hardened. The finish is far smoother and shinier. so i took my handles off, the ones i sprayed the other day, polished these with the wet and dry and what a massive difference.
Mon Apr 14 2014 7:55pm |
thanks for the tip there gazzc! the shop said two layers clear coat max, but on the tailgate trim i put 4 thin layers for extra protection. it kinda made sense, especially on the things that are being man handled thanks again. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Tue Apr 15 2014 7:55am |
MXSRR Member Since: 25 Aug 2013 Location: Lowestoft Posts: 228 |
....especially on the things that are being man handled thanks again.
Tue Apr 15 2014 9:10am |
ok so little update with pictures. stopped off at services yesterday and took some close up pics in the summer sun of the newly painted handles.
Sat Apr 19 2014 11:06am |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 |
This was inspirational. I love the 2000 wet and dry video on making it smooth, guessing thats the key. I'm going to do this on my front grill - I bought it for £50 on ebay, its the honeycomb look - it came in chrome, so I'm going to do it in Stornoway grey. Just ordered the paint and primer and sanding sheets. I'll love this! |
Thu Apr 24 2014 11:18pm |
glad you liked/loved it designboy Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Fri Apr 25 2014 7:45am |
Well this weekend I've done my 3 primers - then so far 3 colour layers its the Stornoway grey I've got so I'm tempted to give it another one or two then clear coat it tomorrow I've my 2000 wet and dry ready, I sanded lightly with it on the primer but it revealed the edges in a flash! Its my new grill I'm doing, want it chrome and the surround to match my body work.
Sat May 24 2014 5:32pm |
just make sure that the primer is thoroughly hardened before you do any sanding. at least 24 hours. i wouldn't bother sanding the primer anyway, unless there are imperfections. you mentioned that sanding revealed the edges...i found this also and the way i got around this was to make sure that i smoothed the sharper edges with 800 wet and dry before spraying with primer.
Sat May 24 2014 6:05pm |
Awesome, then last coat on about 10 mins ago so I'll fire on a clear coat in 50 then give it the night to cure then tomorrow give it another one or two.
Sat May 24 2014 7:07pm |
how's it going with the front grille, designboy?
Sun Jun 01 2014 9:48am |
Mine worked a treat! Been afraid though to let anyone wash it with a pressure washer lol
Sun Jun 01 2014 4:33pm |
