Home > General > The suspension lowers after time
martyn05
United Kingdom 2006 Range Rover Sport Supercharged Bonatti Grey
Hi all,
I have had my 2006 RRS SC for a couple of weeks now and I wanted to ask you a question about the suspension.
When I park my car up, after a few hours / overnight the suspension has lowered quite a bit.
When I next get into my car and start it up, it raises up to standard driving height.
Is this normal or should it stay at the same height as when I parked it?
I am a bit concerned that there is a problem or leak somewhere.
Many thanks in advance. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #415292 Mon Feb 24 2014 10:00am
mike_D_3781
Hi Martyn05,
For what it's worth, my mrs used to notice that ours does, usually after driving and parking, switching ignition off, it would drop slightly.
I've had the compressor checked on mine and it's fine, maybe someone will be able to shed some light on it.
Mike
Post #415298 Mon Feb 24 2014 10:33am
It's not unusual for the RRS to drop overnight. THe vehicle wakes up every 6 hours and attempts to relevel itself - as the engine isn't running it levels itself downwards. 2012 SDV6 - it's missing a couple of cylinders
Post #415303 Mon Feb 24 2014 12:19pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
mine started doing that just before the suspension compressor failed due to overworking,but mine was doing it more on one side caused by a leaking pipe fixing on top of the airbag,would have been a very cheap fix if i had realised before the compressor burnt out Big Cry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #415331 Mon Feb 24 2014 5:21pm
Paul Holywood
Im in the same situation, I have not had time to check pipes yet, but im toying towards Height sensor or Air valve.
Height sensor because i have a red indicator light on on the display.
when you select access height is there any warnings flashing?
Post #415335 Mon Feb 24 2014 6:05pm
martyn05
I am going to try the different heights when I get a minute and see if any warnings come up.
Occasionally I get suspension fault vehicle lean when cornering but it usually goes off. 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #415342 Mon Feb 24 2014 7:04pm
aljo
set it at standard height and remove the battery overnight
if suspension has not dropped then more likely a height sensor
if suspension has dropped on the front only = possible front valve block
if suspension has dropped on the rear only = rear valve block
you may have to follow all air pipes and check for leaks with soapy water but try the above first and narrow it down a bit Thumbs Up
Post #415344 Mon Feb 24 2014 7:17pm
martyn05
I will try that at the weekend Thumbs Up 2006 RRS SC Bonatti Grey (the 55th car/van I have owned)
2005 GSX 1400 K5
Post #415354 Mon Feb 24 2014 8:37pm
Citizen55
United Kingdom 2006 Range Rover Sport Supercharged Tonga Green
*Thread revival alert!!...*
Anyways, I was searching on a similar problem, and I wanted to ask 'why' the RRS wakes up and attempts to re-level itself. Whats the point/advantage of this? Just curious, cos, I'm not really bothered getting into a car that's on a lean.
Cheers!! 2006 Range Rover Sport 4.2 s/c with Arden bodykit
Post #489984 Fri Mar 04 2016 3:37pm
Mr Rusty
Scotland 2013 Range Rover Sport SDV6 Autobiography Fuji White
Good idea Thumbs Up
Intrigue with your profile photo! What happened that ur poor RRS got into that sitch? Shocked 2015 RRS AB SDV6, Fuji White, Ivory
2012 RRS HSE SDV6, Sumatra Black and Ivory
Audi A5, 3.0 TDI, Gone
Audi TT, 3.2 V6, Gone
BMW 5 series tourer, Gone
Post #490007 Fri Mar 04 2016 7:43pm
Tim in Scotland
Chris that photo was from launch day (literally in this case!) in 2005 when a person with shiny new S/C decided to test it off-road on the mud of the River Thames banks somewhere near to Chelsea at low tide................. Unfortunately they had standard tyres on and the treads became slicks and then the tide came in and the owner had to be rescued from his new car by the RNLI inshore lifeboat.......... They also had to mark the submerged car with a buoy so river traffic didn't hit it. It was recovered at low tide the next day but was completely wrecked........... And just after launch in 2005 there was a waiting list of over 9 months for an RRS! The incident featured heavily in the papers much to the embarrassment of the owner. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #490011 Fri Mar 04 2016 8:03pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
My last RRS 2007 dropped after 3 days but more at the back than the front.
As your started and it would return to normal hight.
I used to lower it when parked and it stayed there,
The car will not level any lower than it can go, when you start it and get to 5 mph it will raise to normal hight.
I only had the car for about 6 months and never had a problem with it when driving.
Not a fix but it worked for me for the 6 month. Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #490018 Fri Mar 04 2016 9:09pm
Mr Rusty
Tim, omg! That's quite a story! That's an expensive silly mistake for sure! I must look it up. Rolling with laughter Thumbs Up 2015 RRS AB SDV6, Fuji White, Ivory
Post #490024 Fri Mar 04 2016 11:34pm
wastower
Scotland 2006 Range Rover Sport TDV6 HSE Arctic Frost
Hi
This was happening to my 06 hse and found a leaking air line that runs from front valve block to passenger side bag, replaced and all sorted.
Post #490026 Fri Mar 04 2016 11:45pm
