Home > General > Dog Guard + Load Liner Incompatibility |
The 05-09 & the 09-12 rubber mats are exactly the same, with a little fiddling around, you can make it fit, i had the same issue with mine. I also have a dog and when travalling, it sounds like the dog is tap dancing on the mat so i fitted one of those door mats that you sometimes see outside an office, they also have them on the floor down the fruit & veg isle at you local supermarket (assuming you don't shop at Aldi) Infact ive now taken my dog gaurd out as its not needed anymore. |
Fri Feb 07 2014 11:40pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
How about a dog bed? We put a couple of thin dog rugs in over the top of the rubber mat. They don't slide around and I'm sure they're generally more comfortable with something soft to lie on. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Feb 08 2014 12:26am |
futureian Member Since: 28 Dec 2013 Location: Scotland Posts: 22 |
Dog Bed - Yes, that's what I used yesterday. On my last car I bought a "grippy" piece of carpet and cut it to size. |
Sat Feb 08 2014 11:02am |
Ady - What kind of fiddling about? The dog brackets (one each side) are held in place onto the floor via the chrome hex bolts that are in the boot. The knurled wheel (one each side) passes through the vertical slot in the dog guard and into the hole in the bracket. These vertical slots give you some variation in the actual height of the dog guard but not enough. The two tubular parts of the dog guard that sit on the floor end up sitting on the top of the metal corners of the boot liner (and in this position the dog guard is so high up that the vertical slots in the dog guard are completely above the hole in the bracket and therefore you cannot screw in the knurled wheel). |
Sat Feb 08 2014 11:34am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Iirc you have to cut metal corners off boot mat when fitting dog gaurd - take a look on topix accessories fitting guide Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Feb 08 2014 1:39pm |
Arent there some load liners that are compatible with the dog guard? There are for the discovery Mike
Sat Feb 08 2014 1:42pm |
http://topix.landrover.jlrext.com/topix/co...tabs=false Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Sat Feb 08 2014 1:46pm |
Futureian, all i can remember is that after fiddling around i somehow managed to get it to fit. I know it was tight though. I'm not sure if i sat the dog gaurd on the metal corner plates or not. It was nearly two years ago. As suggested, just cut the metal edge trims off. |
Sat Feb 08 2014 2:37pm |
Thanks for all the replies. In particular to muddywheels for the link. Now where's that stanley knife......
Sat Feb 08 2014 5:31pm |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
I had both of these in mine. The dog guard was blamed for forcing the sides apart allowing load cover to drop into boot. The liner never fitted and bent itself to shape around bottom dog guard mountings but it kept dog hair off carpet and I bought a waterproof dog mattress from Mole Valley Farmers to cover the corners it does actually say in the extras booklet that the load liner and dog guard are not compatible 2x TDV6. SE and HSE. Both returned to sender with issues👀
Sat Feb 08 2014 6:50pm |
Michael calvert Member Since: 09 Feb 2014 Location: near leeds Posts: 219 |
the boot liner i have just bought (the tight Yorkshire man - ebay non LR one) has lipped edges but comes with a carpet inlay that's fitted so the dog and sandwich box wont go sliding across the boot floor
Wed Feb 12 2014 9:23am |
East Coast Sport Member Since: 23 Jul 2013 Location: Angus Posts: 78 |
Anyone looking for dog guard / boot liner google ' boot buddy' and get one from them. I have one with the clear perspex divider which also stops the hair coming into the main cabin. I then fit the LR boot liner on top of the whole thing.
Wed Feb 12 2014 9:47am |
