Home > Faults & Fixes > Steering wheel locked, key fob or something else ? |
mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 17 |
I have a RRS 2010. Over the last few weeks, when i have tried to start the car by pressing the start button and depress the brake pedal, now and then, the car has failed to start. I have at times, attempted several times to get started.
Fri Feb 07 2014 12:40pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
I know you state battery tested, this the main battery and not the fob battery?
Fri Feb 07 2014 12:46pm |
Hi,
Fri Feb 07 2014 2:08pm |
Had the car towed to my local LR dealer. Beadles in Sidcup. The tech there was in two minds and a strange fault for him.
Sat Feb 15 2014 1:59pm |
diamond71 Member Since: 24 Nov 2014 Location: horsham Posts: 25 |
I have the same problem with my 2010 hse, did you have any further problems or did this fix work?. thanks |
Mon Nov 24 2014 5:16pm |
Yes it did work. no problem since fitting of the new part. Been perfect since. Just one of those electronic things that screw up but expensive. |
Mon Nov 24 2014 6:26pm |
