![]() | Home > Faults & Fixes > Steering wheel locked, key fob or something else ? |
mikeyranson Member Since: 31 Oct 2013 Location: london Posts: 17 ![]() ![]() ![]() |
I have a RRS 2010. Over the last few weeks, when i have tried to start the car by pressing the start button and depress the brake pedal, now and then, the car has failed to start. I have at times, attempted several times to get started.
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
I know you state battery tested, this the main battery and not the fob battery?
Had the car towed to my local LR dealer. Beadles in Sidcup. The tech there was in two minds and a strange fault for him.
diamond71 Member Since: 24 Nov 2014 Location: horsham Posts: 25 ![]() ![]() ![]() |
I have the same problem with my 2010 hse, did you have any further problems or did this fix work?. thanks |
Yes it did work. no problem since fitting of the new part. Been perfect since. Just one of those electronic things that screw up but expensive. |
