![]() | Home > In Car Electronics > Which In Car Camera do you recommend?? |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
These are instructions for rrs wiring but ffrr will be a bit different http://www.rrsport.co.uk/forum/topic28640.html?highlight=blackvue
See http://www.disco3.co.uk/forum/topic95619.h...;start=195 for blackvue seller who does the group buy |
I have the DR400G-HD. Also a great piece of kit, |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
there's a good site here where you can get loads of info re dashcams,
Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495 ![]() ![]() ![]() |
ooooo Thanks Scarey !
no problem Jo, and this site has some decent dashcams,
Definitely - always reverse into parking space so camera should catch any careless |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
yes its worth the parking function
Good thinking I actually cant drive into a parking space i always have to reverse in.
for this you'll need to get a dashcam with a decent internal battery or the other alternative is to connect to a permanent live feed and then you might risk a flat battery as the new range rover has an un-capacitated battery fitted, even the fbh only works for 17 minutes instead of the 30 minutes in the proper fullfats.... |
Fitted power magic to protect battery so no worries |
that should be a standard fitment on the L405 |
I hear you - think power magic switches my camera off on icy mornings when I really need it but heaters take all the juice so box protects battery |
the problem i see in having the motion/g sensor on is that in most cases the car park will be on private ground so there's not much the police can do if any damage is caused to your vehicle whether caught on camera or not. |
