Home > Faults & Fixes > ABS activates when cornering ??
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
Hi all ....long time no see, right.... on the 08 plate 2.7.........normal (for me) driving on twisty bits or roundabouts getting a noise and judder that feels like the ABS is activating and the yellow triangle with the circular arrow round it coming up on the dash, just plugged it in and no codes are stored ??? Anyone experienced this or got any pointers ??
Andy 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #412453 Tue Feb 04 2014 3:37pm
andy r
It's just dawned on me that the symbol is for the DSC activating ! 08 2.7 RRS "S"
RS 5
Post #412471 Tue Feb 04 2014 4:12pm
RRS Daz
I think you need to remember your not on the zx but you are in a 2.7 ton car Rolling with laughter
Post #412485 Tue Feb 04 2014 5:15pm
drdelrrs
Depends how quick you were travelling, wouldn't expect the DSC to kick in under normal driving.
Was the road slippery/muddy?
Post #412486 Tue Feb 04 2014 5:15pm
MarkOne
Uneven tyre wear can cause this or 1 or more bald tyres.
Post #412506 Tue Feb 04 2014 6:25pm
andy r
Have to admit that has crossed my mind...... the rears are a little worn on the inside edges........they've done 33k so not bad ! 08 2.7 RRS "S"
RS 5
Post #412554 Tue Feb 04 2014 9:07pm
Monkeyman
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Same issue
Hi Andy,
Have you managed to sort this? I seem to have the same issue but it only started after fitting a new set of wheels and tyres.
Thanks,
Dave.
Post #412588 Tue Feb 04 2014 10:35pm
andy r
No havent been near the car, been using the 110 due to the inclement weather we are exoeriencing !
If its down to worn tyres then it must be diff wind up causing the slippage. 08 2.7 RRS "S"
RS 5
Post #412600 Wed Feb 05 2014 8:18am
Camelrock
Check tyre pressures first then get rear sus bushes checked for play.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #412960 Fri Feb 07 2014 10:33am
andy r
It doesnt do it with DSC turned off Thumbs Up Thumbs Up 08 2.7 RRS "S"
RS 5
Post #412964 Fri Feb 07 2014 11:57am
Disco_Mikey
Has it had any suspension work, or a wheel alignment done recently?
Could be as simple as the steering angle sensor, needing a calibration. Thumbs Up
Post #413036 Fri Feb 07 2014 10:53pm
Monkeyman
DSC light coming on when cornering to the left...
HI,
I think I may be getting somewhere with my issue at last. The car is currently at the local main dealer for the brake safety recall so I asked them to check the DSC / wheels issue out again for me. I have swapped back to the original set of wheels and tyres and the fault is still there so that's good news I guess. They called me this afternoon saying that they have ran various checks and now say that the steering sensor is faulty and is causing the fault after all. They then quoted me £935.00 to replace the entire steering column as the sensor has become "unbonded" and cannot be repaired. I have a warranty on the car but not with LR so I now have check if this is covered but I am thinking there must be a cheaper way of getting this sorted than a new column surely...am I right?
Thanks,
Dave.
Post #413574 Tue Feb 11 2014 9:01pm
andy r
Thats definately NOT good news !!!!! 08 2.7 RRS "S"
RS 5
Post #415410 Tue Feb 25 2014 11:11am
