Home > Faults & Fixes > heavy steering RRS Supercharged 2006
kenti4264
United Kingdom 2006 Range Rover Sport Supercharged HST Santorini Black
hello
new to this forum just wondered if anyone could help or has had the same problem .. i have a range rover sport supercharged 2006.
i was driving last week, n the steering went really heavy like they was no power steering after few seconds went back to normal.. did this a few times for the next few days on n off. went for a drive yesterday and its stayed heavy all the time now .. any ideas ?? checked the fluid levels n tyre pressures all seem to be ok ?
thanks
Post #412202 Mon Feb 03 2014 9:37am
Disco_Mikey
Quite possibly the lower steering column. Very common fault between RRS + D3
Does the steering feel "lumpy" as you go from lock to lock?
Post #412206 Mon Feb 03 2014 11:28am
kenti4264
yes it does feel lumpy goes heavy n then normal when putting the steering on lock either way .
thanks for the reply
Post #412208 Mon Feb 03 2014 11:35am
Disco_Mikey
My money is on the lower column U/J seizing up Thumbs Up
Not too expensive, £60-£70 or so, unless it is different on the S/C model
Post #412209 Mon Feb 03 2014 11:39am
kenti4264
thanks for the advice ill get it looked at hopefully sometime this week
Post #412210 Mon Feb 03 2014 11:42am
