Home > Technical > Parking brake fault, stereo turns off then clears!
Mrturner
2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all, wondering if anyone has come across this issue before? When starting the car (usually when cold) the parking fault light comes on, the dash flashes loads, and the stereo turns off! After a few seconds it stops, then performs perfectly normally. The car is a 2007 2.7td.
It's been back at the dealer since Friday and they've managed to recreate it, but not yet found out what is causing it. Pretty sure whatever they find will be covered by warranty, it has 6 months of LR warranty left and then 2 years Inchcape warranty. Curious to know if anyone else has had it to know if I get blagged! 07 TDV6 HSE in Stornoway Grey, 20" alloys |08 XF SV8 on order.
Post #411833 Thu Jan 30 2014 12:34pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
My sat nav seems to suffer when it's cold and takes a while to spring to life. Big loads on the battery I think so it may just me your battery complaining?
Post #411924 Thu Jan 30 2014 10:35pm
TDV8Mat
England 2013 Range Rover Sport Supercharged HSE Santorini Black
Slightly different to the fault that I had, but for the sake of 5 minutes checking the wiring loom at the n/s/r wheelarch, I'd say it is worth a go. I didn't take the wheel off, just put the suspension in high.
http://www.rrsport.co.uk/forum/topic34325.html
Post #411946 Fri Jan 31 2014 7:13am
Mrturner
OK I'm being advised that the alternator is faulty, that it is overcharging at 17+ and the safe limit is 16 (but should be 12-14.4). When it exceeds 16 the modules shut down for protection.
Sounds feasible and the alternator is being replaced under warranty but recommendation is a new battery. Mad as the car has been there for 2.5 weeks, I have asked for a replacement as a gesture of goodwill! 07 TDV6 HSE in Stornoway Grey, 20" alloys |08 XF SV8 on order.
Post #413528 Tue Feb 11 2014 3:52pm
