![]() | Home > Technical > Parking brake fault, stereo turns off then clears! |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
My sat nav seems to suffer when it's cold and takes a while to spring to life. Big loads on the battery I think so it may just me your battery complaining? |
TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139 ![]() ![]() ![]() |
Slightly different to the fault that I had, but for the sake of 5 minutes checking the wiring loom at the n/s/r wheelarch, I'd say it is worth a go. I didn't take the wheel off, just put the suspension in high.
Mrturner Member Since: 02 Jul 2013 Location: Notts Posts: 34 ![]() ![]() |
OK I'm being advised that the alternator is faulty, that it is overcharging at 17+ and the safe limit is 16 (but should be 12-14.4). When it exceeds 16 the modules shut down for protection.
