Home > Maintenance & Modifications > Service Reset
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
Service Reset
lo all,
My car is in for a service on Saturday with an independent specialist. The only problem is he wont have the correct diagnostic tool to reset the service light on the dash.
Does anyone on here have the correct equipment to reset it? or any other ideas how I can get it reset once he was completed the service.
Thanks
James
Post #410567 Tue Jan 21 2014 9:23pm
simple1
You can reset them without any equipment!!! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #410580 Tue Jan 21 2014 10:31pm
The thought I had was "how can they check and clear faults if they can't even reset the service indicator?" 2012 SDV6 - it's missing a couple of cylinders
Post #410582 Tue Jan 21 2014 10:33pm
simple1
Have to confess, the thought I had was not much of a specialist if they don't have basic service and diagnostics. Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #410588 Tue Jan 21 2014 10:42pm
Disco_Mikey
Not on an 05MY you can't Whistle
Can only do it through the dash on 08>on MY's Thumbs Up
Would be more worried about this though. Even an entry level Snap-On computer can clear service lights...
Post #410630 Wed Jan 22 2014 8:43am
simple1
Mmm. I tried doing an 05 disco and ended up doing it with Verus but my 07 could be done with dash button. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #410654 Wed Jan 22 2014 12:22pm
Disco_Mikey
The exception is the cars that have had the IPC updated to 08MY spec Thumbs Up
Post #410665 Wed Jan 22 2014 1:11pm
simple1
""I see" said the blind man..... Makes a bit more sense then. Bow down 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #410671 Wed Jan 22 2014 1:46pm
chapman_i.t
lo all,
I am not able to reset the service indicator via the dash on a 55 plate.
Also my specialist has the diagnostics tools for my car, but he said the service indicator light has to be reset via the dealer.
Does anyone have anything to reset the light with to save me having to go to the dealer to get it reset?
Thanks
Post #410827 Thu Jan 23 2014 7:14pm
mse
If he has the diagnostic tools for your car there should be no reason to travel to a dealer...even the most basic tool does it. Mike
2014 Facelift Discovery
Post #410831 Thu Jan 23 2014 7:26pm
simple1
Any local car garage that uses snap on can do it. Sonus or Verus does reset it as does autodata. Bit far from me to offer my help Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #410847 Thu Jan 23 2014 8:12pm
Bodsy
Site Sponsor
I'm in Leicester during the week if you wanted it done and/or some software updates.
Mikey, are you saying if when I do the MY08 updates for clock on the dash, that the service reset will then work for these guys? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #410865 Thu Jan 23 2014 9:47pm
Disco_Mikey
Ian, only tried it on one car, but yes, it worked with the 08MY IPC software Thumbs Up
Though that car also had various other upgrades, so whether it was the IPC alone, or a combination, I am not sure
Post #411117 Sun Jan 26 2014 8:02am
Bodsy
Site Sponsor
I'll have to ask some of my customers to give it a go! Thumbs Up Bodsys Brake Bible
See it HERE
Post #411123 Sun Jan 26 2014 9:33am
Disco_Mikey
Tried it yesterday on another car I had done, and wouldn't work. Must depend on which other software has been upgraded
Post #411275 Mon Jan 27 2014 9:28am
