Home > Maintenance & Modifications > Service Reset |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
You can reset them without any equipment!!! 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Jan 21 2014 10:31pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8988 |
The thought I had was "how can they check and clear faults if they can't even reset the service indicator?" 2012 SDV6 - it's missing a couple of cylinders
Tue Jan 21 2014 10:33pm |
Have to confess, the thought I had was not much of a specialist if they don't have basic service and diagnostics. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Jan 21 2014 10:42pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
Not on an 05MY you can't Can only do it through the dash on 08>on MY's
Would be more worried about this though. Even an entry level Snap-On computer can clear service lights... |
Wed Jan 22 2014 8:43am |
Mmm. I tried doing an 05 disco and ended up doing it with Verus but my 07 could be done with dash button. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jan 22 2014 12:22pm |
The exception is the cars that have had the IPC updated to 08MY spec |
Wed Jan 22 2014 1:11pm |
""I see" said the blind man..... Makes a bit more sense then. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jan 22 2014 1:46pm |
chapman_i.t Member Since: 03 Jan 2011 Location: Derby Posts: 219 |
lo all,
Thu Jan 23 2014 7:14pm |
If he has the diagnostic tools for your car there should be no reason to travel to a dealer...even the most basic tool does it. Mike
Thu Jan 23 2014 7:26pm |
Any local car garage that uses snap on can do it. Sonus or Verus does reset it as does autodata. Bit far from me to offer my help 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Jan 23 2014 8:12pm |
I'm in Leicester during the week if you wanted it done and/or some software updates.
Thu Jan 23 2014 9:47pm |
Ian, only tried it on one car, but yes, it worked with the 08MY IPC software
Sun Jan 26 2014 8:02am |
I'll have to ask some of my customers to give it a go! Bodsys Brake Bible
Sun Jan 26 2014 9:33am |
Tried it yesterday on another car I had done, and wouldn't work. Must depend on which other software has been upgraded |
Mon Jan 27 2014 9:28am |
