Home > Technical > 2 stroke oil in diesel tank tdv6 ?? |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 |
I use 50/50 with the best rapeseed oil you can buy.. |
Wed Feb 05 2014 7:42pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Sorry to reopen this old wound, but here is some interesting test evidence that suggests no benefit from 2SO and the possibility of injector fouling.
Sun Apr 05 2015 10:15pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 |
Thanks, an excellent article and prompting me to reconsider my previous views.
Sun Apr 05 2015 11:56pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
I don't see how that article/those tests can prove any more conclusive than the many reporting improvements in fuel consumption.
Mon Apr 06 2015 9:03am |
Agree that lubricity and cetane are slightly improved which is why I have been using it for over 8 years in my vehicles, but my concern was the issue regarding zinc content. Although I have not experienced any issues so far, and I have never heard it raised as an issue before. does all 2SO have the same zinc issue?
Mon Apr 06 2015 9:33am |
I would assume that they will all be broadly similar but it would still be good practice, in my view, to test many different types. Visiting from DISCO3.CO.UK
Mon Apr 06 2015 9:52am |
Just read the report again, zinc content measured was 15 parts per billion!!!!
Mon Apr 06 2015 10:09am |
I agree completely. Visiting from DISCO3.CO.UK
Mon Apr 06 2015 10:39am |
T'was fine in old fashioned diesel engines with relatively low pressure systems and mechanical injectors.
Mon Apr 06 2015 3:42pm |
Well, after all of that filled up with diesel today and added my usual 2SO in the tank.
Tue Apr 07 2015 5:22am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Just had a look at this link, As this issue is that the process cleans carbon from working parts of engine,then the bores and pistons will be cleared of build up of carbon.And on an older engine will result in lower compression. Not a good thing itisme |
Tue Apr 07 2015 8:04am |
Yes Harry, I read all that 8 years ago when I started adding it.
Tue Apr 07 2015 8:46pm |
