![]() | Home > Maintenance & Modifications > Rear pads to be replaced |
You just push them in they are regular calipers. Its a very easy job. Dealers are robin barstewards |
Use the bible |
steve-r Member Since: 28 Dec 2013 Location: Wales Posts: 14 ![]() ![]() ![]() |
Cheers paddi |
Simple, just push them back, however I would open the bleed nipple first, that way you dump the dirty used fluid, you don't push it back towards the master cylinder |
At the rear, exactly the same as the Disco3. ![]() ![]() |
Brill, and thanks for the nipple advice, I would have just pushed pistons back |
Well managed to change the rear pads today and no problems apart from a warning light now on dash saying check pads. I have replaced the sensor and not sure if this has connected properly. I found that the sensor on the actual pads not to be a nice snug fit.
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 ![]() ![]() |
i had my check break pad light come on, went to change pads today to find there completly fine......
My fronts are fine, but rears had about 2-3mm left on them, new pads new sensor new warning light ...bummer
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
I think you need to check the warning light sensors and possibly fit new. They should be a positive fit by the way, but old ones get brittle and really need replacemnt everyt time with the pads. The sensor wire conections above the chassis in each wheel arch can be a bit fiddly to do.
It's the unused loom connector for the TPMS - which you don't have. 2008 MY Java Black TDV8 HSE ![]() |
Hey thanks Paddi.
Daddyjcool Member Since: 11 May 2012 Location: England Posts: 15 ![]() |
I managed to damage the brake wear sensor when I changed the rear pads, so just stripped the two wires back & tied them together.
Shame on you that's a bodge |
