Home > In Car Electronics > LED interior bulbs
Terryrrs
LED interior bulbs
I thought I would replace some of the interior lights with led.back doors fine, front foot wells fine, boot light fine. I have an issue with the front door lights led will not work any idea what it could be ? Do I need error free bulbs. Oh and another issue I popped one of the rear reading lights out power feed cable shot back into the roof lining I can get hold of it but it does not seem long enough.u Shocked
Terry
Post #408202 Sun Jan 05 2014 4:48pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi Terry
Try turning bulb around sometimes this works Thumbs Up
Supporting the London Air Ambulance with my Brothers
Post #408208 Sun Jan 05 2014 5:35pm
Terryrrs
I tried that Panda but it still didn't Censored work. Thanks for the reply as it does sometimes work and thy are osram bulbs so not crap. Thumbs Up
Post #408210 Sun Jan 05 2014 5:48pm
panda
I take it you tried a bulb you know works? tried in another holder??
Post #408227 Sun Jan 05 2014 6:48pm
Terryrrs
I had to fit some resistors in the end to make the front puddle lights work all the others worked ok. The only problem I have now is the two rear reading lights when I removed the light, the wire is too short and flew back into the roof lining with the connector.. They are about an inch too short. Any ideas apart from getting behind the roof lining?
Terry
Post #409903 Fri Jan 17 2014 5:23pm
Grimps42
England 2005 Range Rover Sport Supercharged HSE Rimini Red
Hi did you get sorted on LED interior lights, I just done mine and all worked fine are your wing mirror puddle light the problem?
Post #410407 Mon Jan 20 2014 10:43pm
rabbutler
Scotland 2010 Range Rover Sport TDV8 HSE Alaska White
Terry
I had the same problem withbthe rear reading lights, they are long enough just thaat one of them was tapped to the roof so gave it a good pull to release the tape now all is good 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack
Now gone - Jaguar XKR4.2 v8 Supercharged
Gone - 08 RRS TDI V8 Java Black, Privacy glass 315 BHP tunit box.
Still have - Merc C200 sport
Yahaha FZ1000
Gone - BMW X5 3.0d sport
Post #411119 Sun Jan 26 2014 9:22am
Terryrrs
Thanks for that I will give it a try.
Terry
Post #411129 Sun Jan 26 2014 1:09pm
Terryrrs
rabbutler wrote:
Terry
Success Thumbs Up both mine were glued to the headlining and it needed a mighty tug to free them thought I was going to end up with two wires poking out of the connector will have no problems in the future. Did you have any problems with the front puddle lights ? Nearly all lights replaced just the sun visors to go and glove box.
Post #411190 Sun Jan 26 2014 5:48pm
dannyccmc
2008 Range Rover Sport 4.4 V8 HSE Alaska White
Terry
Can you please clarify on the resistors used? I just replaced all the lights in my 2011 RRS supercharged and the front lower door puddle lights will only turn on when the car is on. When unlocking via the remote and opening the front doors, the lights won't come one. The LED's are canbus error free. 2011 RRS Supercharged, Santorini Black on Brown/Tan, pretty perfect as is
2008 RRS HSE Lux (sold), Alaska white on Ivory/Ebony, Supercharged front and side grill's, 20" genuine stormer wheels, Supercharged front Brembo brake retrofit, Supercharged exhaust tips retrofit, 2010+ tail lights retrofit, Color coded mirror caps, Nappa leather steering wheel retrofit.
Post #412083 Sat Feb 01 2014 3:22am
Paulcp
2013 Range Rover Sport SDV6 HSE Atacama Sand
Did you ever resolve the front door puddle light problem. Just fitting LED lights to mine and I have exactly the same problem, all others work ok but front puddle lights don't.
Post #437637 Wed Sep 24 2014 6:04pm
Terryrrs
Went to halfords and bought two resistors with connectors already fitted.
Post #437677 Wed Sep 24 2014 8:07pm
Paulcp
Thanks for the info, is it these by any chance
http://www.halfords.com/motoring/bulbs-wip...de-501-kit
Post #437686 Wed Sep 24 2014 8:25pm
Terryrrs
Yes they are the ones I used.
Post #437687 Wed Sep 24 2014 8:28pm
Paulcp
Cheers, looks like a trip to Ipswich tomorrow Thumbs Up
Post #437695 Wed Sep 24 2014 8:38pm
