Home > In Car Electronics > LED interior bulbs |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
Hi Terry
Sun Jan 05 2014 4:35pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
I tried that Panda but it still didn't work. Thanks for the reply as it does sometimes work and thy are osram bulbs so not crap. |
Sun Jan 05 2014 4:48pm |
I take it you tried a bulb you know works? tried in another holder??
Sun Jan 05 2014 5:48pm |
I had to fit some resistors in the end to make the front puddle lights work all the others worked ok. The only problem I have now is the two rear reading lights when I removed the light, the wire is too short and flew back into the roof lining with the connector.. They are about an inch too short. Any ideas apart from getting behind the roof lining?
Fri Jan 17 2014 4:23pm |
Grimps42 Member Since: 28 Oct 2013 Location: Norfolk Posts: 23 |
Hi did you get sorted on LED interior lights, I just done mine and all worked fine are your wing mirror puddle light the problem? |
Mon Jan 20 2014 9:43pm |
rabbutler Member Since: 11 Dec 2009 Location: Aberdeen Posts: 187 |
I had the same problem withbthe rear reading lights, they are long enough just thaat one of them was tapped to the roof so gave it a good pull to release the tape now all is good 2010 Alaska white 3.6TDi v8, heated steering wheel, Ipod connection, Aribica extended leather, Digital TV, voice activation, privacy glass, Dynamic pack Now gone - Jaguar XKR4.2 v8 Supercharged Gone - 08 RRS TDI V8 Java Black, Privacy glass 315 BHP tunit box. Still have - Merc C200 sport Yahaha FZ1000 Gone - BMW X5 3.0d sport |
Sun Jan 26 2014 8:22am |
Thanks for that I will give it a try.
Sun Jan 26 2014 12:09pm |
Success both mine were glued to the headlining and it needed a mighty tug to free them thought I was going to end up with two wires poking out of the connector will have no problems in the future. Did you have any problems with the front puddle lights ? Nearly all lights replaced just the sun visors to go and glove box. |
Sun Jan 26 2014 4:48pm |
dannyccmc Member Since: 15 Nov 2011 Location: Houston, Texas Posts: 10 |
Can you please clarify on the resistors used? I just replaced all the lights in my 2011 RRS supercharged and the front lower door puddle lights will only turn on when the car is on. When unlocking via the remote and opening the front doors, the lights won't come one. The LED's are canbus error free. 2011 RRS Supercharged, Santorini Black on Brown/Tan, pretty perfect as is 2008 RRS HSE Lux (sold), Alaska white on Ivory/Ebony, Supercharged front and side grill's, 20" genuine stormer wheels, Supercharged front Brembo brake retrofit, Supercharged exhaust tips retrofit, 2010+ tail lights retrofit, Color coded mirror caps, Nappa leather steering wheel retrofit. |
Sat Feb 01 2014 2:22am |
Paulcp Member Since: 18 Apr 2013 Location: Suffolk Posts: 327 |
Did you ever resolve the front door puddle light problem. Just fitting LED lights to mine and I have exactly the same problem, all others work ok but front puddle lights don't. |
Wed Sep 24 2014 5:04pm |
Went to halfords and bought two resistors with connectors already fitted. |
Wed Sep 24 2014 7:07pm |
Thanks for the info, is it these by any chance
Wed Sep 24 2014 7:25pm |
Yes they are the ones I used. |
Wed Sep 24 2014 7:28pm |
Cheers, looks like a trip to Ipswich tomorrow |
Wed Sep 24 2014 7:38pm |
