Home > Technical > EPB Strange Problem |
Great - its a lesson that some times, faults are faults!! Mike
Tue Jan 14 2014 4:51pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Agreed! That section needs to be weeded out and restricted in my opinion. It should be a repository of fixes not the general mish mash we have now. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Tue Jan 14 2014 5:55pm |
DaleKit Member Since: 11 Feb 2015 Location: West Yorkshire Posts: 1 |
Hi Mat,
Wed Feb 11 2015 12:58pm |
TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139 |
Hi Dale,
Wed Feb 11 2015 2:32pm |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Well done that man ! , I believe that somewhere on here there are a few posts and problems that often mention this plug, and it has been removed and soldered just like you have done with the wire 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Wed Feb 11 2015 5:19pm |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 |
It is green status lamp wire from parking brake module PBM to instrument cluster IPC
Mon Sep 26 2016 8:06pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 |
Excellent, I've bee watching this thread. Funnily, I was thinking of mentioning that connector and associated wiring, as when I was rummaging around the rear of mine, I noticed that the plastic clamp to the chassis had broken, and it was able to move around. I used some tie-wraps to secure it as a temporary measure. |
Fri Sep 30 2016 6:46am |
Autodoc Member Since: 25 Mar 2020 Location: TN Posts: 3 |
What area are you talking about driver or pass side wheel arch |
Thu Mar 26 2020 12:24am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5024 |
I assume you mean what is n/s/r which is Near Side Rear, which in your case being L/H/D will be the left hand (drivers side) rear fender wheel well.
Thu Mar 26 2020 1:07am |
Thanks for the update!! Just never heard nsr before |
Thu Mar 26 2020 1:21am |
I have the code c1a48 I hope I can find the issue with the wires . The parking brake works and holds and releases, tried clearing the code but it won’t clear . I can hear the actuators working . Is there anything else I should be checking for? |
Thu Mar 26 2020 1:33am |
