![]() | Home > Technical > EPB Strange Problem |
Great - its a lesson that some times, faults are faults!! Mike
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
Agreed! ![]() 2008 TDV8 - it was a labour of love and is much missed |
DaleKit Member Since: 11 Feb 2015 Location: West Yorkshire Posts: 1 ![]() ![]() |
Hi Mat,
TDV8Mat Member Since: 17 Dec 2013 Location: East Yorkshire Posts: 139 ![]() ![]() ![]() |
Hi Dale,
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Well done that man ! , I believe that somewhere on here there are a few posts and problems that often mention this plug, and it has been removed and soldered just like you have done with the wire |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 ![]() ![]() |
It is green status lamp wire from parking brake module PBM to instrument cluster IPC
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Excellent, I've bee watching this thread. Funnily, I was thinking of mentioning that connector and associated wiring, as when I was rummaging around the rear of mine, I noticed that the plastic clamp to the chassis had broken, and it was able to move around. I used some tie-wraps to secure it as a temporary measure. |
Autodoc Member Since: 25 Mar 2020 Location: TN Posts: 3 ![]() ![]() ![]() |
What area are you talking about driver or pass side wheel arch |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I assume you mean what is n/s/r which is Near Side Rear, which in your case being L/H/D will be the left hand (drivers side) rear fender wheel well.
Thanks for the update!! Just never heard nsr before |
I have the code c1a48 I hope I can find the issue with the wires . The parking brake works and holds and releases, tried clearing the code but it won’t clear . I can hear the actuators working . Is there anything else I should be checking for? |
