Home > Maintenance & Modifications > Suspension knocking....again!!!
StuRRS
2007 Range Rover Sport TDV6 HSE Java Black
Morning all
I've spent hours reading the various threads on this ongoing issue, but have a question that I haven't found the answer to so far....
I bought my 57 reg HSE in sept '11 with 49k on the clock. The dreaded knocking was diagnosed and 'fixed' by my local main dealer in march '12 (replaced ARBs at a cost of £185) at 53k miles. I've now done 67k and the knocking has returned Big Cry
I realise components wear out, but is this 'normal'? I have loads of service and maintenance documentation from the previous owner and I don't think the bushes were replaced before March '12, so I'm a bit peed off that they seem to have gone again Neutral
Car is in for MOT next Week and I've asked for the suspension to be looked at at the same time. I'm going to question the longevity of the previous 'fix' but has anyone got a view on this?
Cheers Stu
2023 RRS p440e SE Dynamic
2018 Discovery 5 SDV6 HSE Santorini gone
2014 SDV6 HSE Santorini gone
2007 TDV6 HSE Java gone
2003 Discovery TD5 ES gone and missed
2008 Q7 gone
2005 X5 gone
2003 X5 gone
2000 Freelander 2.5 V6 gone- not missed!!
Post #407458 Sun Dec 29 2013 10:14am
adigorn
Did your dealer changed bushes only
or clamps as well
(lr introduced new type of clamps to prolong bushes life time)
Post #407459 Sun Dec 29 2013 11:30am
StuRRS
Looks like just bushes- receipt says "BUSH - STABILIZER BAR LINK" 2 of these for the princely sum of £23.50 + vat
Perhaps I should have had the clamps too Neutral Stu
2008 Q7 gone
2005 X5 gone
2003 X5 gone
Post #407460 Sun Dec 29 2013 11:47am
flack
Try this drive the car at 10 to 15 mph and dab the foot brake hard quickly, if it knocks then you need lower arms changing, its a common fault on older cars...
Flack Thumbs Up
Post #407465 Sun Dec 29 2013 12:50pm
StuRRS
Thanks Flack, just tried that and seems ok. Just getting the tell tale clonk on speed bumps and when moving the steering wheel side to side at slow speeds.
I guess I'm hoping someone will tell me the bushes should last more than 14000 miles with no off roading....... Stu
2008 Q7 gone
2005 X5 gone
2003 X5 gone
Post #407483 Sun Dec 29 2013 3:17pm
adigorn
depending if the new bushes were fitted with old (read - non modified) clamps
than its quite possible they will not last longer Sad
Post #407488 Sun Dec 29 2013 4:48pm
Paul Holywood
My Stealer wants £185 per set plus labour works out at circa £1,200 are we talking about the same bushes?
Post #407501 Sun Dec 29 2013 8:50pm
StuRRS
Shocked crikey, hope not Paul
Maybe your stealer is talking about replacing the arms as well. Labour was £130 plus the vat, but they only replaced the bushes, which sorted the knocking and seemed to tighten up the front end, if you know what I mean. It's only in the last month or so the knocking has returned.
Not sure if it helps you but part number is RVU500011 Stu
2008 Q7 gone
2005 X5 gone
2003 X5 gone
Post #407504 Sun Dec 29 2013 9:31pm
Rangeybath
Have exactly the same problem with mine. Great thread folks - will go down the garage loaded with knowledge Surprised
Post #407535 Mon Dec 30 2013 12:11pm
£1200 sounds more like the cost of replacing the anti roll bar itself (assuming a dynamic response ARB is fitted).
Either that or they're planning to split the vehicle in order to do the bushes - that's several hours of labour cost straightaway. As people have replaced the ARB bushes on their driveways, it would seem that splitting the vehicle to do them is somewhat excessive. 2012 SDV6 - it's missing a couple of cylinders
Post #407540 Mon Dec 30 2013 1:24pm
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Sounds like that's the cost of replacing the front lower suspension arms. My dealer quoted me a very similar figure for lower arms. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #407543 Mon Dec 30 2013 1:56pm
jack.bauer
I have so far;
Replaced front lower arms
Front arb bushes
Links
Replaced rear anti roll bar (for another problem)
Still have the knocking but it does sound different this time. 07 TDV8 + BAS map
Post #407681 Tue Dec 31 2013 11:38pm
Disco_Mikey
Lower steering column Thumbs Up
Visually OK, but when removed from the car, quite often you find play in the sliding joint or U/J Thumbs Up
Post #407685 Wed Jan 01 2014 12:21am
StuRRS
jack.bauer wrote:
I have so far;
Front arb bushes
Links
Good news then Whistle at least we are keeping the mechanics in work Rolling Eyes Stu
2008 Q7 gone
2005 X5 gone
2003 X5 gone
Post #407698 Wed Jan 01 2014 8:54am
jack.bauer
replaced front ARB now.
noise still there.
LR looking at replac a bush in the lower steering column i believe 07 TDV8 + BAS map
Post #431440 Thu Jul 24 2014 9:10am
