![]() | Home > Technical > found my air suspension leak.... need to know what to do now |
Or one of the sensors is shafted or adjusted as mentioned previously. Mike
shadrack Member Since: 12 Sep 2013 Location: north east Posts: 220 ![]() ![]() |
is there any diy scanner programs for land rover ive had bmws for 10 years and have bmw1.4.0 and inpa so can do all my own fauld codes, suspension adjustments etc myself, just need similar for landrover |
Blackbox solutions MSV2 I use for d3, d4, RRS
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
The air hose is 6mm. If you can't get a fitting, PM me and I can maybe help out.
Part of the suspension design is that if you're driving and the car detects something under the chassis etc it will raise to extended mode to clear the obstacle.
