Home > General > RRSport, warm in the winter??? |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
If it's a 2007 it should have a fuel burning heater so will warm quickly and the heating system with heated seats is a warm place to be. We have had -10-12 and have never been cold in the car and I can't drive in a coat. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Mon Dec 09 2013 8:47am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
UK disesls get the Webasto fuel burning axillary heater as standard. I would expect a Scandanivian vehicle to be similarly specified. You might consider retro fitting a timer to the heater - that will allow the heater to start the warming of the car before you get in. 2012 SDV6 - it's missing a couple of cylinders
Mon Dec 09 2013 8:57am |
Norway_viking Member Since: 08 Dec 2013 Location: In the deep and cold woods Posts: 3 |
Thank you for the reply.
Mon Dec 09 2013 9:47am |
For fairly little money, you could also add a remote to the FBH, meaning you can then instigate the warm up at your convenience and not just on the timer
Mon Dec 09 2013 9:57am |
Thanks for the tip. |
Mon Dec 09 2013 4:18pm |
