![]() | Home > General > Arc Pipe |
'57 TDV8 HSE in Hertfordshire? Must help you then |
Kravman Member Since: 11 Feb 2013 Location: Perth Posts: 11 ![]() ![]() ![]() |
Thank you Paddi it is the rear. I think I'll give it a top up as recommended and call Autoland as I'm only 45 mins away |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9023 ![]() ![]() ![]() |
There are two failure modes for the active roll bars. The first is a leak around the pipe junction. This is fixable by replacing the pipe or seal (Bobby has posted stuff about this before). The second is a leak from the actuator itself. This is not repairable and requires a replacement unit. This happened to mine. Luckily it was covered by the warranty but the cost would have been about £1300 IIRC. 2012 SDV6 - it's missing a couple of cylinders
A pictorial always helps:
Well done Paddi, that explains it perfectly |
Paul Holywood Member Since: 14 Dec 2013 Location: Hertfordshire Posts: 307 ![]() ![]() ![]() |
Hi Paddy I've been reading your posts on this topic and wondered if I can ask you a question. I have been advised today my rear arb system is showing signs of a oily mist , and explained its very serious and will cost 4-5k for the repair, when it finally goes wrong.. After three or four hours of trying to get up of the floor ![]() He wasn't specific of the precise area, but said there was evidence of an oily mist, should I panic now, or wait..! Ps, I have had no suspension faults as yet. NOTE: I asked for a thorough and complete check over while my TDV8 was having a service as the car is new to me. He did advise being a indi, he would not take on the job, and was only guessing at the costs from LR. |
Hi Paul,
Hi Paddy
Its great to feel that TDV8 on full power but I hope you are observing all the usual precautions recommended to look after your turbos; 30 secs of idle after a cold start, no hard acceleration until fully warmed up and a couple of minutes idle before shutting off. Change the oil and filter between services. Might sound a bit OCD but much preferable to kaboom and a bill for £9k |
I trashed a turbo on my company van through starting it and zooming off, expensive learning curve.
I had my rear ARB replaced by a LR dealership about 18 months ago and it cost about £1400 all in, IIRC. The bar alone is about £800 and the rest was labour and VAT. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks RRSTDV8
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Easily done without body off ![]() |
I think they did take the body off, or at least tipped the rear up a bit, to do it. 2012 SDV6 - it's missing a couple of cylinders
