![]() | Home > Technical > 05 Range Rover Sport Tdv6 SE starts then stalls |
Could it be some of the glowplugs faulty? Would a diagnostic check with a suitable fault code reader help to pin point the problem? According to other posts on the forum getting the glowplugs out is a real 'beeatch' to do so if it proves necessary make sure you take it to someone with lots of experience with this job on this engine. 2008 MY Java Black TDV8 HSE
monkers2003 Member Since: 04 Mar 2013 Location: Chester Posts: 28 ![]() |
I'm not sure. Ive heard MAF sensor and ecu temp sensor issues could be causing a problem.
Yea will do. Well it sometimes runs a little rough at idle. And I do remember a couple of months ago a diagnostics check showed cylinder 5 misfiring. |
Glow plugs or injectors |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
or HP Pump ![]() |
Not convinced, but these cars are strange beasts. Could be a brake light bulb |
wasn't making it up speaking from experience ![]() |
Just an update, the cars going to land rover today and they are keeping over night to see how it starts in the morning. It took a while to start this morning as it was around +1 degrees.
Saeedasghar Member Since: 10 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
Get them to check the O rings on the fuel pipes mate some times they wear down and start taking air in. |
Big Dave Member Since: 16 Aug 2013 Location: London/Essex Posts: 42 ![]() ![]() ![]() |
I'll be interested in what they say on this, I had an identical issue with my SC and found it to be a low battery. Now I put it on the C-tek once in a while and I've not had a problem since. 2011 Evoque Si4 Dynamic plus lux
Claus1949 Member Since: 14 Dec 2013 Location: Marhsfield Posts: 4 ![]() ![]() ![]() |
Hi
Just an update on this.
thanks for that, just wondering what's causing this problem. Mine started first time today, but stalled yesterday.
