Home > General > 2012 Timed Climate???? |
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 |
How the hell has that happened?
Thu Nov 21 2013 10:31am |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
I have had my timed climate enabled via the recommendation by MSE and now I want to fit the aerial and receiver so I can use a remote. I PM d Duckworths and then spoke to Dan on Tuesday but he hasn't come back to me and I appreciate he is a busy man. I am trying to find the part numbers for the aerial and receiver. My sport is a 2012 HSE Lux and has TV fitted, has anyone had the same model done and know the part numbers that I need. Also tried my local stealer but they can't/won't supply the parts, any help appreciated. thanks MY16 AUTOBIOGRAPHY Indus silver with some toys
Thu Nov 21 2013 8:47pm |
Glad you got it sorted
Thu Nov 21 2013 9:08pm |
Read that there may be different aerials depending if TV is fitted or not???
Thu Nov 21 2013 9:14pm |
No problem, glad its all sorted
Thu Nov 21 2013 10:28pm |
Thanks anyway MY16 AUTOBIOGRAPHY Indus silver with some toys
Thu Nov 21 2013 10:33pm |
Been away on holiday but back yesterday so decided to fit the receiver and aerial so I could use the remote function. Took no more than 20 minutes in total and is a very easy DIY job. Anyone considering this its easy, do not waste your money paying a main dealer crazy prices, have a go yourself MY16 AUTOBIOGRAPHY Indus silver with some toys
Mon Dec 02 2013 6:10pm |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5636 |
Sounds good - do you need the dealer to activate/pair Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Mon Dec 02 2013 6:43pm |
I had it activated when the screen was enabled and pairing is only a question of removing a fuse for 5 seconds then replacing it and pressing a button on the remote. All very easy MY16 AUTOBIOGRAPHY Indus silver with some toys
Mon Dec 02 2013 6:51pm |
Ah - so I guess I will need mine activated as I only have timed climate at the moment Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Mon Dec 02 2013 7:57pm |
Yes the remote operation is a separate function to the screen option and needs to be enabled. Anyone that is having the timed climate enabled should make sure that the remote option is also enabled at the same time and then the upgrade to remote operation is just a hardware add on with no further software costs MY16 AUTOBIOGRAPHY Indus silver with some toys
Mon Dec 02 2013 8:15pm |
Htailor23 Member Since: 01 Jan 2014 Location: London Posts: 7 |
Hi MSE, do you know anyone in London area that can activate the FBH time control, and also supply the Ariel and remote to my 2012 RRS? How much would this cost? Thanks |
Wed Jan 01 2014 4:16pm |
No sorry no one in London Mike
Wed Jan 01 2014 7:21pm |
