![]() | Home > General > 2012 Timed Climate???? |
Macdaddy Member Since: 12 May 2012 Location: NW Posts: 101 ![]() |
How the hell has that happened?
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
I have had my timed climate enabled via the recommendation by MSE |
Glad you got it sorted |
Read that there may be different aerials depending if TV is fitted or not???
No problem, glad its all sorted
Thanks anyway |
Been away on holiday but back yesterday so decided to fit the receiver and aerial so I could use the remote function. Took no more than 20 minutes in total and is a very easy DIY job. Anyone considering this its easy, do not waste your money paying a main dealer crazy prices, have a go yourself |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Sounds good - do you need the dealer to activate/pair |
I had it activated when the screen was enabled and pairing is only a question of removing a fuse for 5 seconds then replacing it and pressing a button on the remote. All very easy MY16 AUTOBIOGRAPHY Indus silver with some toys
Ah - so I guess I will need mine activated as I only have timed climate at the moment |
Yes the remote operation is a separate function to the screen option and needs to be enabled. Anyone that is having the timed climate enabled should make sure that the remote option is also enabled at the same time and then the upgrade to remote operation is just a hardware add on with no further software costs |
Htailor23 Member Since: 01 Jan 2014 Location: London Posts: 7 ![]() ![]() ![]() |
Hi MSE, do you know anyone in London area that can activate the FBH time control, and also supply the Ariel and remote to my 2012 RRS? How much would this cost? Thanks |
No sorry no one in London Mike
