![]() | Home > Off Roading & Green Laning > Spare Wheel question (255/55/19 General grabber AT) |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Should be fine. 2012 SDV6 - it's missing a couple of cylinders
GibRRS Member Since: 20 Aug 2012 Location: Gibraltar Posts: 30 ![]() ![]() ![]() |
Thanks RRSTDV8.
The /55 is 25mm larger in diameter than the /50.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
A 255 mixed with a 250 could be an issue when driving - recommend emergency use and restrictions as per handbook |
I assume he's going to be running 255/55 on the road and wants to carry the same size as a spare... |
I have two sets of wheels, I use the AT tyres with 19" wheels when going to Morocco or doing a bit of off roading. The 20" set are for motorways etc. I initially had only 4x 19" wheels, but thought there might be an issue should I need to use the spare, originally designed for use with the 20" rims. I've just purchased a used rim and new tyre to have a same size spare but have not yet tried to fit it on the spare wheel winch.
