Home > Off Roading & Green Laning > Spare Wheel question (255/55/19 General grabber AT)
GibRRS
Gibraltar 2007 Range Rover Sport TDV6 SE Stornoway Grey
Hi Guys, a quick question (apologies if this has been asked before), Will a 255/55/19 AT tyre fit where the spare wheel should go? If so would it knacker the winch?
regards
GibRRS
Post #401736 Mon Nov 11 2013 9:23pm
Should be fine. 2012 SDV6 - it's missing a couple of cylinders
Post #401744 Mon Nov 11 2013 10:12pm
GibRRS
Thanks RRSTDV8.
regards
GibRRS
Post #401751 Mon Nov 11 2013 10:32pm
The /55 is 25mm larger in diameter than the /50.
Out of interest, why are you going for the /55 over the /50 aspect ratio tyre? 2012 SDV6 - it's missing a couple of cylinders
Post #401754 Mon Nov 11 2013 10:38pm
muddywheels
Milk Float Man
A 255 mixed with a 250 could be an issue when driving - recommend emergency use and restrictions as per handbook Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #401756 Mon Nov 11 2013 10:42pm
I assume he's going to be running 255/55 on the road and wants to carry the same size as a spare... Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #401757 Mon Nov 11 2013 10:45pm
GibRRS
I have two sets of wheels, I use the AT tyres with 19" wheels when going to Morocco or doing a bit of off roading. The 20" set are for motorways etc. I initially had only 4x 19" wheels, but thought there might be an issue should I need to use the spare, originally designed for use with the 20" rims. I've just purchased a used rim and new tyre to have a same size spare but have not yet tried to fit it on the spare wheel winch.
Regards
GibRRS
Post #401760 Mon Nov 11 2013 10:50pm
