![]() | Home > Technical > Suspected rear diff failure |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
For completeness, I'd just mention that the work, carried out by a LR dealer, cost c.£1400 of which labour was about £300.
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
You mentioned the fitting of winter tyres - they are usually noisier, often causing a hum or rumble ?
I've got a feeling it might be to do with the tyres as it seems a bit less of a hum in the wet. The rear is definitely quieter with the new rear diff so I guess it really was on its way out. 2012 SDV6 - it's missing a couple of cylinders
