Home > Technical > Suspected rear diff failure
I was wondering if it might be tyre related. Don't have any others to try at the moment though. 2012 SDV6 - it's missing a couple of cylinders
Post #401417 Fri Nov 08 2013 1:56am
For completeness, I'd just mention that the work, carried out by a LR dealer, cost c.£1400 of which labour was about £300.
Another reason to have a warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #401705 Mon Nov 11 2013 4:07pm
drdelrrs
You mentioned the fitting of winter tyres - they are usually noisier, often causing a hum or rumble ?
A worn suspension bush, harmonic damper, powertrain or exhaust mounting can sometimes transmit noise through to the chassis and then the body.
Post #401716 Mon Nov 11 2013 5:54pm
I've got a feeling it might be to do with the tyres as it seems a bit less of a hum in the wet. The rear is definitely quieter with the new rear diff so I guess it really was on its way out. 2012 SDV6 - it's missing a couple of cylinders
Post #401723 Mon Nov 11 2013 6:24pm
