Home > General > YAW Sensor
norman1979
YAW Sensor
After having a few issues with my RRS I finally got a diagnostic machine plugged in.
The error that came up was related to the YAW sensor. The error code was related to open circuit YAW sensor.
The symptoms I am getting are Suspension Lowered, HDC System Unavailable and Special Programs not available along with the traction control light on.
Does anybody know the location of this sensor? Or have any thoughts on how to resolve this?
Post #397314 Sat Oct 05 2013 6:05pm
In the D3 it's under the carpet below the centre floor console between the front seats. I would guess that it's in the same place in the RRS.
http://www.rrsport.co.uk/gallery/albums/us...Sensor.pdf
http://www.rrsport.co.uk/gallery/albums/us...onsole.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #397331 Sat Oct 05 2013 8:48pm
norman1979
Thanks for the help. Much appreciated.
The fault codes I have are
C1A98 Yaw Rate Sensor Circuit
U0416
U0421
I'm beginning to think it may be an issue with the wiring to the yaw sensor
I'm hoping somebody else can share their thoughts Smile
Post #397384 Sun Oct 06 2013 8:58am
U0416 is invalid data received from vehicle dynamics control module
U0421 is invalid data received from the ride level control module
Not sure whether that helps or not. 2012 SDV6 - it's missing a couple of cylinders
Post #397391 Sun Oct 06 2013 11:20am
mitche
2006 Range Rover Sport Supercharged Izmir Blue
U0416
U0421
Hello
Did you find something out in this issue?
I got the exact same problem, did you have any lights lit in the dash?
The ones with red circles, is lit with amber colour on mine....see pic
Any thoughts?
Mike
Post #510366 Sat Nov 19 2016 4:31pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
a friend of mine had the same issue on a d3 turned out to be corroded wires to the yaw sensor
Post #510372 Sat Nov 19 2016 5:26pm
mitche
Ok, where were they corroded? Near the door or closer to it - below the console?
Post #510464 Mon Nov 21 2016 10:54am
hard2beat2014
under the console
Post #510547 Tue Nov 22 2016 5:14pm
mitche
Thanks, much appreciated!!
Mike
Post #510553 Tue Nov 22 2016 6:05pm
Kenny_Reed
United States 2006 Range Rover Sport Supercharged Java Black
Mike did you ever figure this out? I have the exact same issues
Post #545558 Thu Jan 11 2018 8:38pm
