![]() | Home > General > YAW Sensor |
In the D3 it's under the carpet below the centre floor console between the front seats. I would guess that it's in the same place in the RRS.
norman1979 Member Since: 24 Apr 2013 Location: London Posts: 21 ![]() |
Thanks for the help. Much appreciated.
U0416 is invalid data received from vehicle dynamics control module
mitche Member Since: 19 Nov 2016 Location: Sweden Posts: 3 ![]() ![]() |
Hello Did you find something out in this issue? I got the exact same problem, did you have any lights lit in the dash? The ones with red circles, is lit with amber colour on mine....see pic ![]() Any thoughts? Cheers Mike |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
a friend of mine had the same issue on a d3 turned out to be corroded wires to the yaw sensor |
Ok, where were they corroded? Near the door or closer to it - below the console? |
under the console |
Thanks, much appreciated!!
Kenny_Reed Member Since: 11 Jan 2018 Location: California Posts: 3 ![]() ![]() ![]() |
Mike did you ever figure this out? I have the exact same issues |
