Home > Technical > arc oil
jack.bauer
arc oil
hi chaps
I understand the power steering fluid and ARC oil is one and the same
if I need to top up the ARC with 3 bottles
but also wish to carry out that TSB for squeeky steering wheel (LTB00072)
how many bottles should I need?
what im trying to get at is, i have a two birds one stone scenario i believe.
the TSB requires a flush and refill. that should take care of the ARC top up too right? so 5 bottles? 07 TDV8 + BAS map
Post #396432 Fri Sep 27 2013 10:48pm
Paddi
Jack,
The way you phrased your questions it could be inferred you think the Dynamic Response System and Power steering system are connected together.
Yes - they both use the same specification fluid (LR cold climate PAS) but No - they aren't connected on the same hydraulic circuits. They are separate systems.
You need 4 litres of PAS for the power steering flush::
"Continue to flush the power steering system until 4 litres of
power steering fluid has been added to the power steering
reservoir. This should take approximately 30 seconds."
The capacity of the Dynamic Response System is 2.4 litres:
"General Specifications
Item Specification
Dynamic Response fluid Texaco Cold Climate Fluid 33270
Capacity 2.4 Liters (4.2 pints) (2.5 US quarts)
System pressure Variable between 3-165 bar dependant on lateral acceleration"
 2008 MY Java Black TDV8 HSE
Post #396789 Tue Oct 01 2013 2:54pm
jack.bauer
I was just checking this again today and noticed I never came back to you! Yes you've answered my question, I did think they may be connected somehow! So how do these two distinct systems use the same spec fluid anyway? Just curious 07 TDV8 + BAS map
Post #403441 Sun Nov 24 2013 11:48am
Paddi
Well they are both hydraulic systems. Choice of fluid is made by the manufacturers presumably based on lubricicity and viscosity and compatibility with the components of the system. Not all fluids are compatible so it is important to top up with the same stuff. My guess is that Land Rover chose to use a common fluid in the interests of simplicity and economy of scale. How's that? 2008 MY Java Black TDV8 HSE
Post #403467 Sun Nov 24 2013 6:58pm
LOCUST
i was going to post a topic about arb fluid, what is the spec ? cani buy from halfords ?
Post #403483 Sun Nov 24 2013 8:39pm
Paddi
Halfords best avoided for this kind of thing. I don't have any faith in their advice and the prices are way too high.
Faced with the same dilemma but just for topping up I sourced the fluid from Duckworths (LSTC50519 at about £20 per litre) Big Cry
A good motor factor is always better than Halfords in terms of advice and price.
You could try asking Steve a.k.a BoringOldGit at Advanced Motor Factors if he can recommends a less expensive equivalent? 2008 MY Java Black TDV8 HSE
Post #403568 Mon Nov 25 2013 12:43pm
SurreyHills
Can you suggest a stockists for this either in central London or near Guildford?
Post #424689 Mon May 19 2014 11:53am
safcjo64
try your local fleet factors,just google it.
usually very reasonable if you buy in 5l
Post #427183 Sat Jun 14 2014 7:10pm
safcjo64
sorry i meant 25l
Post #427403 Mon Jun 16 2014 10:40pm
