![]() | Home > Technical > arc oil |
Jack,
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
I was just checking this again today and noticed I never came back to you! Yes you've answered my question, I did think they may be connected somehow! So how do these two distinct systems use the same spec fluid anyway? Just curious 07 TDV8 + BAS map |
Well they are both hydraulic systems. Choice of fluid is made by the manufacturers presumably based on lubricicity and viscosity and compatibility with the components of the system. Not all fluids are compatible so it is important to top up with the same stuff. My guess is that Land Rover chose to use a common fluid in the interests of simplicity and economy of scale. How's that? 2008 MY Java Black TDV8 HSE
LOCUST Member Since: 02 Oct 2013 Location: ESSEX Posts: 75 ![]() ![]() |
i was going to post a topic about arb fluid, what is the spec ? cani buy from halfords ? |
Halfords best avoided for this kind of thing. I don't have any faith in their advice and the prices are way too high.
SurreyHills Member Since: 19 May 2014 Location: Surrey Posts: 2 ![]() ![]() |
Can you suggest a stockists for this either in central London or near Guildford? |
safcjo64 Member Since: 14 Jun 2014 Location: noth east Posts: 5 ![]() ![]() ![]() |
try your local fleet factors,just google it.
sorry i meant 25l |
