![]() | Home > Technical > FBH Can I test it works before the winter |
Corns-88 Member Since: 20 Feb 2013 Location: cheshire Posts: 26 ![]() ![]() ![]() |
I've searched for an hour but not found the answer so I thought I'd ask. Is there a way of testing to see if my FBH is still working /activated or switched on on my 2007 hse before the bad weather sets in. I know wifey has driven it around with the fuel light on and after 4 starts/strikes you are out. So is there an easy way to check or not. It was working last year. 07 tdv8 stornoway grey at home tucked up
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
There's no "easy" way, all require a tool of some kind.
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
I guess that since it works of the ambient temperature being 3C (I think) or less, you could try covering the temperature sensor with ice !
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Martin's reply just reminded me that you can find links to buy the necessary lead and instructions on how to access the FBH using Webasto's software from the D3 sister site. 2012 SDV6 - it's missing a couple of cylinders
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Get a tin of freeze it spray and spray the Ambient temp probe this should fire it up.. failing that remove the ambient probe and place in freezer for 20 mins and then quickly replace it and it should fire up, if it does not then you have a locked out FBH that needs resetting to work fully again.
