Home > Technical > FBH Can I test it works before the winter
Corns-88
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
I've searched for an hour but not found the answer so I thought I'd ask. Is there a way of testing to see if my FBH is still working /activated or switched on on my 2007 hse before the bad weather sets in. I know wifey has driven it around with the fuel light on and after 4 starts/strikes you are out. So is there an easy way to check or not. It was working last year. 07 tdv8 stornoway grey at home tucked up
x type jag work and back hack
x5 Gone - never fully loved or cared for
Disco td5 gone - saved a fortune on ear plugs
Freelander gone - one of the first and worst
early disco gone- A tractor in a fur coat.
Post #395349 Wed Sep 18 2013 9:30am
I think the only way is to use a test device e.g. IIDTool, Faultmate or fit the BAS remote system which allows priming of the system etc. 2012 SDV6 - it's missing a couple of cylinders
Post #395371 Wed Sep 18 2013 2:20pm
Martin
Site Administrator & Owner
There's no "easy" way, all require a tool of some kind.
Either a LR diagnostic system/tool as above or the Webasto ThermoTest software and an OBD adapter. Like this site? Buy some RRSPORT goodies to show your support!
Post #395375 Wed Sep 18 2013 2:31pm
drdelrrs
I guess that since it works of the ambient temperature being 3C (I think) or less, you could try covering the temperature sensor with ice !
Do it before starting the car as the engine must be cold.
Post #395397 Wed Sep 18 2013 7:11pm
Martin's reply just reminded me that you can find links to buy the necessary lead and instructions on how to access the FBH using Webasto's software from the D3 sister site. 2012 SDV6 - it's missing a couple of cylinders
Post #395418 Wed Sep 18 2013 9:03pm
flack
Get a tin of freeze it spray and spray the Ambient temp probe this should fire it up.. failing that remove the ambient probe and place in freezer for 20 mins and then quickly replace it and it should fire up, if it does not then you have a locked out FBH that needs resetting to work fully again.
Flack Thumbs Up
Post #395429 Wed Sep 18 2013 10:26pm
