Home > Technical > What have I done? |
Preston-rr Member Since: 10 Sep 2010 Location: Preston Posts: 239 |
Hi all, help? Not sure what I have done or if I have even done anything to cause this. The passenger door won't always open? Sometimes it is fine other times it isn't. Have I programmed it somehow accidentally? Any ideas?
Sat Sep 14 2013 2:53pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
my passenger rear some times does this |
Sat Sep 14 2013 4:48pm |
It happens about 80% of the time? Any ideas before I book her in?
Sat Sep 14 2013 7:51pm |
Is usually the bottle, bu could also just be the pump has come out of its hole. Bodsys Brake Bible
Sat Sep 14 2013 8:14pm |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 |
@Preston
Sat Sep 14 2013 10:19pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need a new door lock as it sounds like it is failing.
Sun Sep 15 2013 9:22am |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
My drivers side lock went a couple of weeks ago, got to the stage I was opening the car windows with the key fob and reaching in - be prepared for a shock, mine cost £260 fitted for a new latch!
Sun Sep 15 2013 10:02pm |
wullie Member Since: 27 Mar 2009 Location: Ayrshire Posts: 81 |
hi mark
Sun Sep 29 2013 5:38pm |
Not yet, been driving me mad. Flack has ordered the parts for me and is hopefully fitting later this week. Needs a new latch and cable. Why are you having the same problem? 2014 RRS HSE, SVR body kit fitted.
Sun Sep 29 2013 8:24pm |
I did have' If your a diy'r you can do it yourself it's a bit awquard but cheaper than the garage, once the new lach was fitted I stripped the old one, there's two small motors in the lock and it's them that burn out well usually just one of them.
Mon Sep 30 2013 11:38am |
