Home > Technical > What have I done?
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
What have I done?
Hi all, help? Not sure what I have done or if I have even done anything to cause this. The passenger door won't always open? Sometimes it is fine other times it isn't. Have I programmed it somehow accidentally? Any ideas?
Thanks
Mark 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #395000 Sat Sep 14 2013 2:53pm
Could be a dodgy latch
I had one and I found not only did it not open sometimes, but it also didn't lock Exclamation
Post #395002 Sat Sep 14 2013 3:08pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
my passenger rear some times does this
Post #395013 Sat Sep 14 2013 4:48pm
Preston-rr
It happens about 80% of the time? Any ideas before I book her in?
Also has anyone had a leak on their washer fluid bottle? Filled mine today and it all ran straight through? Is it likely to be the bottle or a pipe? Was pouring out so I suspect it's the bottle. 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #395033 Sat Sep 14 2013 7:51pm
Bodsy
Site Sponsor
Is usually the bottle, bu could also just be the pump has come out of its hole. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #395036 Sat Sep 14 2013 8:14pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
@Preston
I had a similar fault on my car.
The washer fluid just disappeared, and magically reappeared on my drive.
In my case it was the coupling fron the pump-motor to the hose that leaked.
I loosened the screws that hold the inner arch, bent it backwards (after taking off the Wheel).
That gave me enough room to inspect the rearside of the washer bottle.
I just took off the hose, applied a little amount of silicone, and now it is bulletproof.
I hope that this is of some help.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #395043 Sat Sep 14 2013 10:19pm
flack
You need a new door lock as it sounds like it is failing.
Flack Thumbs Up
Post #395048 Sun Sep 15 2013 9:22am
codfather
Scotland 2010 Range Rover Sport 3.0 TDV6 SE Santorini Black
My drivers side lock went a couple of weeks ago, got to the stage I was opening the car windows with the key fob and reaching in - be prepared for a shock, mine cost £260 fitted for a new latch!
Dave MY10 TDV6 SE (debadged Wink ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Gone: a comprehensive list of imprezas and a Merc ML AMG
Post #395120 Sun Sep 15 2013 10:02pm
wullie
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
hi mark
did you ever get your door repaired ?
wullie
Post #396577 Sun Sep 29 2013 5:38pm
Preston-rr
Not yet, been driving me mad. Flack has ordered the parts for me and is hopefully fitting later this week. Needs a new latch and cable. Why are you having the same problem? 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #396585 Sun Sep 29 2013 8:24pm
wullie
I did have' If your a diy'r you can do it yourself it's a bit awquard but cheaper than the garage, once the new lach was fitted I stripped the old one, there's two small motors in the lock and it's them that burn out well usually just one of them.
There is a post in this form somewhere with pictures, fair helped me out when I done mine, anyway hope you get it sorted out ok.
cheers
Wullie Cool
Post #396620 Mon Sep 30 2013 11:38am
