Home > Maintenance & Modifications > Cheap fix for GPS Aerial.
Page 1 of 3 123>
flack
I have had a few gps antennas failed lately in the shark fin aerial and was looking around for a cheaper alternative even the breaker yards want �50.00 for a second hand one, so this is my fix for �6.49p.
http://www.rrsport.co.uk/gallery/albums/us...%20RRS.pdf
Flack Thumbs Up
Post #394754 Thu Sep 12 2013 10:07am
Paddi
Flack - that's an exemplary post. Top work Bow down
There's been a couple of posts looking for help with lost GPS reception recently.
Could a moderator add this to the list of 'HOW TOs' on the technical section perhaps?
Cheers,
Paddi 2008 MY Java Black TDV8 HSE
Post #394759 Thu Sep 12 2013 11:50am
Big Dave
That's my task for the weekend then. Thank you for a superb guide. 2011 Evoque Si4 Dynamic plus lux
2007 Audi TT 3.2 V6
2005 Sport Sc
Post #394787 Thu Sep 12 2013 5:25pm
panda
2007 Range Rover Sport TDV6 HSE Zermatt Silver
Hi Flack I have problem with my satnav. you cannot program route on postcode as only numbers appear on screen. top corner of screen shows GPS with red cross through it, so I take it no GPS, but when driving pointer shows you moving so I thought this would be controlled by GPS??
Any ideas??
Thanks
PANDA
Supporting the London Air Ambulance with my Brothers
Post #416048 Sat Mar 01 2014 4:39pm
flack
Yes its your Gps aerial that has failed, the pointer will still move but not track on the map or follow a road because it does not know where it is.
Just do the fix as above and you will be fine.
Flack Thumbs Up
Post #416052 Sat Mar 01 2014 5:52pm
panda
Many thanks Flack will order one and give it a try.
PANDA Thumbs Up Thumbs Up
Post #416053 Sat Mar 01 2014 5:58pm
panda
How good was your post flack Thumbs Up Thumbs Up Done it today, Idrilled 13.5 mm hole and kept cable long so no need to cut and join cable. The hardest bit was getting the plate above the head lining back on with the 2 10m mm nuts other than that all went good.
On sat nav screen I cant do postcodes it just shows numbers no letters. Sad any ideas??
Panda
Post #421851 Mon Apr 21 2014 3:23pm
jimbg
Check which country you have selected. I think it defaults to Belgium!! 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #421854 Mon Apr 21 2014 3:41pm
panda
Thanks jimbg. Read the posts played with screen and found on Belgium reset all normal now. Thumbs Up Thumbs Up Thumbs Up
Post #421855 Mon Apr 21 2014 3:46pm
flack
Yes its a good cheap fix..
Flack Thumbs Up
Post #421860 Mon Apr 21 2014 5:12pm
Techstyles
Belgium 2005 Range Rover Sport TDV6 HSE Maya Gold
Hi Guys,
I think my gps aerial is gone, keeps taking me off track and not able to resync on it's own. I can using the 753 menu reset my location and it does relocate me to where I am. But could be the direction calibration as after I set off somewhere eventually it misplaces me. Any ideas?
But before I start dismantling things, can someone explain flack's guide....what happens once we have the new mast aerial, where do we run the new aerial wire to? Does it go down to the dvd unit itself? I took a photo so if anybody cares to point it out.
Thanks
Tech
Post #447383 Sun Jan 04 2015 4:22pm
panda
If you get the part all the work is done above rear luggage area in the roof space. Remove aerial solder in new part and replace. do it in the dry as water would come through holes in roof. It is a bit awkward locating nuts but I am 22 stone and not so agile but done it ok.
Thumbs Up Thumbs Up
PANDA
Post #447386 Sun Jan 04 2015 4:36pm
Techstyles
So we just get a new aerial, cut the wire from it and solder the old wire onto the new aerial circuit board? So removing any casing from the new aerial we just want a new board basically?
Thanks for the reply Panda Smile
Post #447403 Sun Jan 04 2015 7:58pm
ABSport
Well done fantastic mod. Thumbs Up
Post #447408 Sun Jan 04 2015 8:17pm
panda
I fitted printed circuit board into where old one was removed, drilled a hole large enough for connector to go through so didn't cut wire. Secured in with hot glue gun. I think (a while since I done repair).
PANDA
Post #447409 Sun Jan 04 2015 8:20pm
Page 1 of 3 123>
