![]() | Home > Maintenance & Modifications > Cam belt update |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
Last belt I done on a TDV6 looked like this |
tizifred Member Since: 22 Jun 2013 Location: Southampton Posts: 17 ![]() ![]() ![]() |
Mine was nowhere near that bad.
Sporting Chance Member Since: 08 Aug 2013 Location: Oxford Posts: 32 ![]() ![]() ![]() |
They was very lucky to get away with that one Mikey. Current 2010 RRS TDV8
Changed one on mates D3, it was in same sort of condition, 106k miles and 7 years old. Had similar bits missing and frayed and also the rubber deposits on idler and inside cover. Might be a case of sending this info to LR, as always thought the service interval was too large. Personally, I would think 70k or five years would be safer time limit.
70k/7yrs
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 ![]() ![]() ![]() |
looks like this is on my "to do list" also |
Thought the V6 was 115k or 10 years. 2x TDV6. SE and HSE. Both returned to sender with issues👀
TDV6 is 105k miles, or 7years |
The oracal according to LR dealers is wrong then |
Tis on the LR Service Schedule |
IDB Member Since: 09 May 2013 Location: Chorley, Lancs Posts: 18 ![]() ![]() ![]() |
Just had front and rear belts changed @ 74000 on my 56 plate 2.7 as a precaution. The belts looked ok when we got them off but better to be safe than very sorry. Thanks again to Flack for doing a good job. |
IDB did you do it yourself, if so how did you find it?
Swifty Member Since: 29 Aug 2013 Location: North East Posts: 11 ![]() ![]() |
Any body got the dimensions of the locking pins for the cam shafts and crank shaft, o/d and length would be good for the TDV6.
