Home > Technical > Engine misfire on idle 4.2
DC_Supercharged
Hi - my 4.2 First Edition Sport is misfiring on idle - the spark plugs have just been changed and the diagnostics read out is displaying P0302 cylinder 2 misfire
P0303 cylinder 3 misfire
P0304 cylinder 4 misfire
P0308 cylinder 8 misfire
i have replaced all 8 spark plugs and coil packs of the cylinders that have registered a fault,
misfire is only really noticeable on idle, once a steady engine speed is held it runs much better
engine management light is not on at the moment
Post #392548 Fri Aug 23 2013 8:40am
Was this a problem before you changed the plugs Question
Post #392552 Fri Aug 23 2013 9:26am
DC_Supercharged
Yes - the engine management light was on too....but now off...
Post #392553 Fri Aug 23 2013 9:28am
DC_Supercharged
Would an engine ECU reflash /update help?
Post #392558 Fri Aug 23 2013 10:00am
Not sure an ecu reflash will help, that will clear any fault codes stored, but i'd check the maf sensor first.
Post #392782 Sat Aug 24 2013 9:49pm
DC_Supercharged
Ok thanks - will do
Post #392869 Mon Aug 26 2013 10:26pm
Bobby
Generally, such misfires can also be classified as "random misfires".
And the possible causes would be:
* ECM to ignition coil primary circuit faults
* Ignition coil failure
* Spark plug failure/fouled /incorrect gap
* Fuel delivery pressure (low/high)
* Fuel injector circuit fault(s)
* Fuel injectors restricted/leaking
* Fuel injectors continuously open
* Fuel contamination
* Cylinder compression low
* Worn camshaft/broken valve springs
* Valve clearance adjustment
Use an approved diagnostic tool to do some coil tests, check the spark plug condition and gap, check the fuel pressure, check for fuel injector problems. Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #392894 Tue Aug 27 2013 10:16am
DC_Supercharged
Thanks - the spark plugs and coil packs have been changed a week ago by a senior BMW technician - he identified one of the old spark plugs was not in properly. The new ones are all in as they should be now.
Post #392900 Tue Aug 27 2013 11:32am
Never trust a BMW technician... Next he will be telling you to trade in your sport for an X5 Whistle Are you sure he hasn't sabotaged your sport just for this reason Question Laughing
Post #392910 Tue Aug 27 2013 12:41pm
DC_Supercharged
Lol - I hope not - we both work at the same diagnostics company....
Post #392913 Tue Aug 27 2013 12:48pm
Edwards1987
England 2006 Range Rover Sport Supercharged HST Zambezi Silver
Hi guys
Did you manage to cure this problem as I have the same problem with my 2006 4.2 sport. Mine is misfiring on cylinders 3 and 5,the misfire clears after 1000 rpm. any advice would be very grateful
Post #394810 Thu Sep 12 2013 7:59pm
DC_Supercharged
The misfire is still there on all eight cylinders - more noticeable on start up - but then subsides as the engine warms up.
Overall it drives nice and smooth but it's still very annoying that the misfire exists - after all the diagnosing and money spent.
Post #428074 Mon Jun 23 2014 12:57pm
vnitos
South Africa
Mine does exactly the same - misfire on startup and idle - and engine management light comes on and stays in until reset. Dealer found a bit of oil in one of the spark plugs, which they dried and apparently its better now. I told them to keep the car until they 100% sure that the issue has been resolved.
Post #431490 Thu Jul 24 2014 3:50pm
DC_Supercharged
Let me know when you get it back and if the dealer did any more work to rectify...
DC
Post #431491 Thu Jul 24 2014 3:53pm
vnitos
South Africa
will do
Post #431493 Thu Jul 24 2014 4:08pm
