![]() | Home > Technical > Engine misfire on idle 4.2 |
Was this a problem before you changed the plugs |
DC_Supercharged Member Since: 14 Aug 2013 Location: Warwickshire Posts: 27 ![]() ![]() ![]() |
Yes - the engine management light was on too....but now off... |
Would an engine ECU reflash /update help? |
Not sure an ecu reflash will help, that will clear any fault codes stored, but i'd check the maf sensor first. |
Ok thanks - will do |
Generally, such misfires can also be classified as "random misfires".
Thanks - the spark plugs and coil packs have been changed a week ago by a senior BMW technician - he identified one of the old spark plugs was not in properly. The new ones are all in as they should be now. |
Never trust a BMW technician... Next he will be telling you to trade in your sport for an X5 |
Lol - I hope not - we both work at the same diagnostics company.... |
Edwards1987 Member Since: 12 Sep 2013 Location: Surrey Posts: 1 ![]() ![]() ![]() |
Hi guys
The misfire is still there on all eight cylinders - more noticeable on start up - but then subsides as the engine warms up.
vnitos Member Since: 03 Nov 2010 Location: pretoria Posts: 32 ![]() ![]() |
Mine does exactly the same - misfire on startup and idle - and engine management light comes on and stays in until reset. Dealer found a bit of oil in one of the spark plugs, which they dried and apparently its better now. I told them to keep the car until they 100% sure that the issue has been resolved. |
Let me know when you get it back and if the dealer did any more work to rectify...
will do |
