Home > Technical > lower arm knocking vs roll bar clunking
jack.bauer
do these sound similar?
i took the car in to rectify the knocking sound. lower arm bush worn, so whole arm replaced.
noise is still there and told its the rollbar bush.
question is, shouldnt that have been obvious the first time it went in?
do they sound so similar that you need to eliminate one to expose the other? 07 TDV8 + BAS map
Post #391473 Mon Aug 12 2013 12:25am
Disco_Mikey
They do sound very similar.
However, there are ways to determine where the noise is coming from.
Post #391476 Mon Aug 12 2013 6:48am
jack.bauer
Thanks mikey 07 TDV8 + BAS map
Post #391668 Tue Aug 13 2013 6:51pm
H16UUP
United Kingdom 2006 Range Rover Sport TDV6 SE Zermatt Silver
I found a big lever bar between lower wishbone & ARB showed up 2mm play in my N/S front lower BJ. Couldn't get any play in ARB bushes.
Changed it in 2hrs.
Not too difficult thanks to Mikey's helpful Wiki Thumbs Up
 2006 TDV6 SE, Zermatt Silver
Post #392439 Wed Aug 21 2013 10:22pm
jack.bauer
2 hours...some indy is charging £260 for that. thats more like 4! 07 TDV8 + BAS map
Post #392442 Wed Aug 21 2013 11:29pm
H16UUP
Ah, well it's all the excellent virtual training I've had! 2006 TDV6 SE, Zermatt Silver
Post #392443 Wed Aug 21 2013 11:34pm
Disco_Mikey
And indy charging £130 per hour Shocked
Need to get my ass down to London Laughing
Post #392451 Thu Aug 22 2013 6:59am
s335
You can tell the difference. Usually if you tap the brakes like a cadence braking and it knocks its the lower arms and if you shake steering wheel side to side at low speeds it usually the anti roll bar bushes
Post #399043 Sat Oct 19 2013 3:55pm
