Home > Off Topic > Any Defender owners on here?
MisterAdam
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
A Defender 90 pick up has come up for sale not to far from me, I've never had one before so I'm going to look at it tonight and possibly buy it if it's decent and we can work out a good price. Going to be taking a mate along who's got a Defender and know's what to look for.
It's a 1987, 114k miles, 9 months mot, 1 month tax, 200tdi engine. Below from the advert:-
[URL=]
[/URL]
"I have owned it for approx 3 years. In that time I changed the old knackered 2.5td engine for the fantastic 200TDI out of a K reg Discovery. I bought this for something a bit different to the normal euro boxes for the drive to work and as a daily use. I haven't been off road at all as that wasn't why I got it. All the panels are straight and tidy. The chassis is solid with only the normal welding on the rear crossmember been done. The bulkhead is solid and even the air vents under the windscreen work ok.
During my ownership I have replaced:-
As soon as I got it I wire brushed the rear 2/3rds of the chassis. 2 coats of red oxide primer then covered it all in Shultz.
Fuel tank
Changed clutch last September when I did the engine swop
Radiator when I did the engine swop
Brakes. Front calipers, discs and pads. Rear cylinders and shoes. All flexi pipes and copper lines.
Fitted the alloy wheels off the discovery with 30mm spacers
Ifor Williams canopy
Apart from the above it is original so remember its getting old. It starts without the need of heater plugs and goes like a train. The heater does work, but its always on hot hot hot as I caught the cable when fitting the engine. The temperature gauge is now faulty. As soon as you turn the ignition on the needle goes as far as it can to the hot side of the gauge. This is even before the engine has started. This means its the sender unit going straight to earth. Its a cheap part and easy fit, I just don't have the time to sort it at the moment."
I've had a quick look on the autotrader and prices seem to vary quite widely. I know it's hard to give a value without seeing a car properly, but does anyone have an idea as to what I want to be looking at paying for this is it's a good'un?
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Previous: Mercedes CLS, BMW 330cd M sport, Nissan 200sx, Impreza STi, EP3 Civic Type R
Post #390943 Mon Aug 05 2013 11:04am
muddywheels
Milk Float Man
If I was you I'd join http://www.defender2.co.uk/forum/ and ask on there Thumbs Up
Always fancied one myself but having had a loaner and been in a mates not sure I could live with one day to day Laughing Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #390948 Mon Aug 05 2013 11:42am
MisterAdam
I don't want to incase the seller is a member on there Laughing
Yes the are a bit of an acquired taste, but I've never had one so need to scratch that itch. Luckily it won't be a daily, more of an option when I want to remind myself that car's have come a long way, and that my daily driver van isn't so bad afterall Laughing Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Post #390949 Mon Aug 05 2013 11:56am
Gary
Depends on price but 90/110 Defenders are generally priced on condition not on year, one thing I will say the arches are either too big or have been relocated higher to accomodate bigger wheels and those D1 wheels are too small which unless the speedo cable has been changed will give you a higher speed reading than you are actually going, See my gallery for a pic of mine to get an eye for the proportions
Post #390971 Mon Aug 05 2013 3:26pm
SRE
Spain
Looks like a bodge.
Possibly a non coiler converted to coil.
I have driven loads of them, cramped unless you are vertically challenged. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #390974 Mon Aug 05 2013 3:41pm
Jeremy @ Grange Barnet LR
Looks fine, not keen on the arches or Disco alloys but they are easy to sort.
Disco 200 is a good and well proven conversion (and a billion times better than the old Turbo diesel)
Certainly not a non coiler converted - so dont worry there (I think its the tasty arches possibly giving that impression!).
Value wise really does depend on how solid it is. Check the chassis and bulkhead carefully. If solid I'd pay £3000 for it and budget a few pounds to sort the wheels and arches.
If rotten run away (and dont trust the description, check for rust yourself!).
Also check the engine number is on the block and has been updated on the V5.
If you need anymore PM or email me jeremy.jackson@hadleygreen.co.uk (I've got one or two Defenders Whistle )
Post #390976 Mon Aug 05 2013 3:50pm
chilly
United Kingdom 2006 Range Rover Sport Supercharged HST Java Black
for me he says he gone to the trouble of replacing the engine (and wire brushing and sealing chassis) but then couldnt be bothered sorting out a wire or hose he says he caught putting it in and the quick easy fix for the thermostat gauge that is quick and easy and cheap but hasnt done
makes me wonder what else he hasnt bothered with
also somethng really off with thoose wheels looks like it would roll over haha only the dead truely know peace,
Bootneck its not a job its a way of life!
Post #390977 Mon Aug 05 2013 3:50pm
James @ Grange Barnet LR
United Kingdom 2012 Range Rover Sport SDV6 HSE Stornoway Grey
There's a few of us who've had that itch! Sound advice from Jeremy.
Mine was once upon a time very similar to the one you're going to look at, although 309Tdi.it was a Caledonian Blue basic pickup on white steel wheels.
James Thumbs Up
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Follow us on Twitter: @GrangeBarnetJLR Thumbs Up
Last edited by James @ Grange Barnet LR on Mon Aug 05 2013 4:00pm. Edited 1 time in total
Post #390979 Mon Aug 05 2013 3:58pm
MisterAdam
They look like after market arches, i spy some rivet holes along the top edge of them whereas your lower ones are smooth and much lower. The wheels do look like smarties in thoese arches Laughing
SRE wrote:
Looks like a bodge.
Luckily for me I'm 5 foot 9 so never had the problem of being to tall for anything Sad
I don't mind the arches but I cant help but think it needs an enormous set of tyres to match them. If they've been riveted on then they'd most likley stay as I don't want to be getting into arsing around repairing panels etc.
Appriciate your post! Cool
I'll question that plenty, good to know it's a cheap quick and easy fix though! Thumbs Up
Yeah the wheel's really don't do it for me in the slightest, but they're easy enough to change Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Post #390980 Mon Aug 05 2013 3:59pm
BigCat8810
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
also something really off with those wheels looks like it would roll over haha
Chilly makes some very valid points, it does not look right with those arches & wheels, seems odd not to have bothered sorting out the thermo or whatever the issue is. Not sure I'd consider it as there are plenty of examples out there if you want a Defender, although £3k you are entry level end of the pricing scale.
As stated by others, always take a good look underneath looking for rot or significant off-road damage and check all docs and serial numbers etc as lots of these vehicles have history and not all of it is good.
That said I really miss mine and will be acquiring a replacement at some stage. --------------------------------------------------------
RRS TDV8 Black/Black (Gone)
RRS TDV8 Stornaway (Gone)
RR Vogue TDV8 (Gone)
RRS 4.4V8 (Gone)
Defender 110 300tdi (Stolen, much missed)
RR Vogue V8 P38 (Gone)
LR 90 TD (Gone)
Post #390981 Mon Aug 05 2013 4:00pm
BigCat8810
James Thumbs Up
That's a great looking vehicle, would love something like that.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  --------------------------------------------------------
RRS 4.4V8 (Gone)
LR 90 TD (Gone)
Post #390982 Mon Aug 05 2013 4:02pm
MisterAdam
I'll be sure to check everything thoroughly, the lad I'm taking is also an mot tester so he knows where to be looking etc.
So if I'm paying less than 3k it's an alright deal, asking as its not a shed? Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Post #390989 Mon Aug 05 2013 5:13pm
Sub 3k is fine, as long as all ok! Have a good drive first Thumbs Up
Post #390990 Mon Aug 05 2013 5:14pm
BigCat8810
I'm not very current on prices etc but I think you should be able to find a half decent one for £3k, avoid the TD as it has a bad rep (although I had one for a few years with no issues) but 200 or 300Tdi are pretty solid engines.
Great fun to drive. --------------------------------------------------------
RRS 4.4V8 (Gone)
LR 90 TD (Gone)
Post #391000 Mon Aug 05 2013 6:36pm
MisterAdam
I bought it Smile
[URL=]
[/URL]
Got a hell of a deal and she's a little belter, very tidy underneath, very tidy overall really, goes stops turns etc all as it should do. Wheel's most definitely need to go in favor of something that'll fill those arches Twisted Evil
Came with a ton of spares, full set of standard wheels with tyres, disco transfer box, some range rover seats, exhaust, tons of assorted parts, even a little model 90 pick up Laughing
Got a few little bits to sort out but nothing horrific, going to put together a list this weekend and make a start on it, might throw some pictures up when I've given it a once over :)
Post #391016 Mon Aug 05 2013 10:56pm
