Home > Faults & Fixes > Parking Sensor Issues..HELP
l2saqib
I have just purchased a 2007 RRS Revere. When the car is in reverse and the parking sensors are activated, the sensors work as they should, however, once the car is put into Drive the sensor continues to 'beep' for a further 5-7 seconds.
Any advice?
Many thanks Range Rover Sport HSR
2.7 TDV6
Post #390499 Wed Jul 31 2013 4:48am
danRR
They stay active until u get above a cettain speed after puttin it back into drive, normal operation... I belive u can turn this off from memory, im sure iv seen this on the SDD lists,
Post #392072 Sat Aug 17 2013 8:43pm
Chrale
As above, they stay on until you get above a certain speed. Theres a button on the centre of the dash that you can switch them off with. Its near the lock/unlock buttons above stereo display. 2007 TDV6 HSE
Post #392092 Sun Aug 18 2013 9:37am
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
there is a fuse you can pull to disable the sensors, in the fuse box behind the glove compartment.
I'm currently fighting this, Ive fixed the rear by replacing the sensors and loom, so far I've changed 2 front sensors and its better but not perfect, so will be changing the remaining 2 in the hope that will be the end if it
Strangely all my sensors could be heard ticking when the problem started, its worth putting the rrs in drive and putting your ear up to each sensor where a ticking noise can be heard.
Search the forum there are a few articles Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #392095 Sun Aug 18 2013 10:07am
Jd99
Northern Ireland 2005 Range Rover Sport Supercharged Java Black
Sensors coming on when driving
My sensors have started coming on when driving in traffic- is this normal?
Post #393074 Wed Aug 28 2013 10:04pm
flydive
I believe that in earlier cars like yours, the sensors would become active automatically below a certain speed(10Km/h?).
There was an update of the software that eliminates that and makes the sensors come on only selecting reverse or with the switch on the dash '08 RRS TDV8
Post #393089 Thu Aug 29 2013 7:23am
