![]() | Home > Faults & Fixes > Parking Sensor Issues..HELP |
danRR Member Since: 17 Aug 2013 Location: London Posts: 3 ![]() ![]() |
They stay active until u get above a cettain speed after puttin it back into drive, normal operation... I belive u can turn this off from memory, im sure iv seen this on the SDD lists, |
Chrale Member Since: 14 Feb 2013 Location: North East Posts: 77 ![]() ![]() ![]() |
As above, they stay on until you get above a certain speed. Theres a button on the centre of the dash that you can switch them off with. Its near the lock/unlock buttons above stereo display. 2007 TDV6 HSE |
Montythegod Member Since: 31 Aug 2012 Location: Medway, kent Posts: 268 ![]() ![]() ![]() |
there is a fuse you can pull to disable the sensors, in the fuse box behind the glove compartment.
Jd99 Member Since: 28 Aug 2013 Location: Belfast Posts: 5 ![]() ![]() ![]() |
My sensors have started coming on when driving in traffic- is this normal? |
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
I believe that in earlier cars like yours, the sensors would become active automatically below a certain speed(10Km/h?).
