Home > General > suspension problem
dal1557
suspension problem
hi there all
when driving my rrs i can hear the air compressor working when going over bumps is this normal?
am having rear end handling problems could there be a leak in the system ?the air compressor is new just a couple months old D Ledingham
Post #387643 Wed Jul 03 2013 8:23am
Could be the relay - did they change it when they changed the compressor? They are known to get a little "tired" and cause compressor symptoms.
Other than that, there are 3 valve blocks for the EAS, a main one by the compressor and one for each axle of the vehicle. Obviously, along with the connections to the air springs themselves, that's a lot of connections. 2012 SDV6 - it's missing a couple of cylinders
Post #387646 Wed Jul 03 2013 9:13am
dal1557
Hi
Do you know what the relay is called? D Ledingham
Post #387647 Wed Jul 03 2013 9:15am
simple1
Considering that the car is handling like a suet pudding and the suspension is playing up, I recommend you take it to someone who knows what they are doing! Rolling Eyes it's not just your safety at stake.... Whistle 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #387648 Wed Jul 03 2013 9:53am
flack
Sounds like you have a leak and thats why the compressor is running, if they have changed it to the new type they would have to have changed the pipe work get this checked as this could be the cause of your leak.
Flack Thumbs Up
Post #387650 Wed Jul 03 2013 10:13am
An overview of the system from the D3 manual (which is basically the same on the RRS) http://www.rrsport.co.uk/gallery/albums/us...tion~0.pdf 2012 SDV6 - it's missing a couple of cylinders
Post #387686 Wed Jul 03 2013 4:22pm
