Home > General > suspension problem |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
Could be the relay - did they change it when they changed the compressor? They are known to get a little "tired" and cause compressor symptoms.
Wed Jul 03 2013 9:13am |
dal1557 Member Since: 30 Jun 2013 Location: Montrose Posts: 23 |
Hi
Wed Jul 03 2013 9:15am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Considering that the car is handling like a suet pudding and the suspension is playing up, I recommend you take it to someone who knows what they are doing! it's not just your safety at stake.... 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Jul 03 2013 9:53am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Sounds like you have a leak and thats why the compressor is running, if they have changed it to the new type they would have to have changed the pipe work get this checked as this could be the cause of your leak.
Wed Jul 03 2013 10:13am |
An overview of the system from the D3 manual (which is basically the same on the RRS) http://www.rrsport.co.uk/gallery/albums/us...tion~0.pdf 2012 SDV6 - it's missing a couple of cylinders
Wed Jul 03 2013 4:22pm |
