Home > Maintenance & Modifications > 2006 2.7 OIL PUMP AND SEAL
GIXER JOHN
2006 Range Rover Sport TDV6 HSE Santorini Black
Can antone tell me the part no for the uprated oil pump/casting for 2006 2.7D.
Also need oil seal part no. Maybe dan @ duckworths???
Doing cambelts soon and dont want to risk BIG DISASTER Sad Sad Thumbs Up
thanks
Post #386966 Tue Jun 25 2013 4:32pm
SRE
Spain
http://www.rrsport.co.uk/forum/topic31141.html?highlight=oil+pump
Post #386972 Tue Jun 25 2013 5:00pm
aljo
the modified oil pump is LR013487 but i think the 2006 model will have this oil pump fitted anyway, 2007 & 2008 seem to be the problem years and lr reverted back to the previous designs
give a lr dealer your vin number they should be able to tell
might save you a few pennies Thumbs Up
Post #387009 Tue Jun 25 2013 10:07pm
Bodsy
Site Sponsor
Nah... They didn't revert back to a previous design. The part number you quoted is now the only one to fit for all 2.7 regardless of year. And is the stronger design. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #387036 Wed Jun 26 2013 1:33am
aljo
Embarassed I stand corrected
Post #387070 Wed Jun 26 2013 1:16pm
GIXER JOHN
Thanks for the help guys .pump ordered fitting soon with belts.just need a timing tool now Thumbs Up
Post #387139 Thu Jun 27 2013 7:17am
GIXER JOHN
Post #387140 Thu Jun 27 2013 7:17am
flack
Don't forget you need to lock the flywheel so that you can undo the crankshaft bolt and once removed if you move the crank your timing position will be lost as there is no keyway on the crankshaft.
Allow yourself a full day to the job..
Flack Thumbs Up
Post #387148 Thu Jun 27 2013 9:43am
