Home > Maintenance & Modifications > 2006 2.7 OIL PUMP AND SEAL |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
http://www.rrsport.co.uk/forum/topic31141.html?highlight=oil+pump |
Tue Jun 25 2013 4:00pm |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
the modified oil pump is LR013487 but i think the 2006 model will have this oil pump fitted anyway, 2007 & 2008 seem to be the problem years and lr reverted back to the previous designs
Tue Jun 25 2013 9:07pm |
Nah... They didn't revert back to a previous design. The part number you quoted is now the only one to fit for all 2.7 regardless of year. And is the stronger design. Bodsys Brake Bible
Wed Jun 26 2013 12:33am |
I stand corrected |
Wed Jun 26 2013 12:16pm |
GIXER JOHN Member Since: 05 Sep 2012 Location: pinxton nottingham Posts: 13 |
Thanks for the help guys .pump ordered fitting soon with belts.just need a timing tool now |
Thu Jun 27 2013 6:17am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Don't forget you need to lock the flywheel so that you can undo the crankshaft bolt and once removed if you move the crank your timing position will be lost as there is no keyway on the crankshaft. Allow yourself a full day to the job.. Flack |
Thu Jun 27 2013 8:43am |
