![]() | Home > Technical > Pdc fuse |
firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461 ![]() ![]() ![]() |
Just realised this is in the wrong section sorry If you took some fog and put it in a jar, would it be missed. |
Ok, update, it is fuse 36 the numbers are at the top of the fuse not the bottom...... Duh!
update:
Oh yes, however just finished cleaning it and it,looks mint..... Not sure what will fall of next but when they are clean and working there's nowt better. Oh I forgot, when I was climbing in through the passenger side because of the door lock, I found the side step was rotten, so that was another £150 If you took some fog and put it in a jar, would it be missed. |
